khamul02's Avatar
Cam Damaged in Shipping
Well, I just got some really nice Cams in the mail but there wasn't anything protecting the end and it took a hit. Is this still useable? I plan on sending everything off to have it checked and machine if needed. It is a non contact surface. Thoughts?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-26-2021, 01:01 PM
Puny Bird
Mark Henry's Avatar
That sucks but it's just the drive for the adjusting wrench. Did it damage the threads?
Get the cam magnafluxed and checked for straightness, if a pass you're good to go.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 02-26-2021, 01:45 PM
Puny Bird
Mark Henry's Avatar
BTW did that chip off? Cams are quite hard but brittle, not sure but I think some type of cast.
I'd defiantly get it magnafluxed, but I think it wouldn't crack, likely it would just break.
Old 02-26-2021, 01:53 PM
khamul02's Avatar
It chipped off as the ends weren't padded at all. You can see a hole in the box where it hit something. Everything else seems fine. Will the machine shop handle the magnaflux process?
Tom Hutchinson
Old 02-26-2021, 03:59 PM
Puny Bird
Mark Henry's Avatar
Yes.
Old 02-26-2021, 04:33 PM
It's a 914 ...
stownsen914's Avatar
When I buy cams now, I ask the seller to wrap the cams individually and double box them, to survive the abuse that shippers inflict.
Old 02-27-2021, 04:06 AM
When I sent mine off I slid them in two lengths of white pvc pipe and caps. You can get them at Lowe’s or Home Depot for chump change.
Ken
1986 930 2016 R1200RS
Old 02-27-2021, 04:47 AM
Typo?
Mark,
Was this a typo?
Tony
Old 02-27-2021, 05:17 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Although I believe the cams are serviceable (your inspection is important) if this situation bothers you, it is easy to cut the end off the cams, bore and tap them to accept the later bolt and conical washer vs the spring washer /nut design.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-27-2021, 06:31 AM
khamul02's Avatar
It is really disappointing because just a piece of cardboard at each end would have kept them perfect. They are both really nice low mileage cams.
I guess I will go with them after inspection.
Do you think they should be sanded some to remove the rough broken surface?
Tom Hutchinson
Old 02-27-2021, 07:59 AM
Sure, why not.
Henry Schmidt
Ph: 760-728-3062
Old 02-27-2021, 08:18 AM
It's a 914 ...
I've also seen damage like that from using the wrong kind of wrench while torqueing the large nut. Either way, assuming no other damage, I'd dress the area with a file and not worry about it.
Old 02-27-2021, 09:19 AM
khamul02's Avatar
That is good to know. Looking at the box, it seems like it occurred during shipping. I took so much care in taking mine off with the Stromski tool only to find they were pitted. Once I got the engine out of the car.. there has been a surprise at every turn.
Tom Hutchinson
Old 02-27-2021, 09:30 AM
Of course there are surprises , you are working on a 30 year old car , but best of luck .
Old 02-28-2021, 08:19 AM
Location: behind the redwood curtain, (humboldt county) california
Surprises offer the possibility of upgrading and learning new stuff :-)
Welcome to the slippery slope - might as well enjoy the ride ;-)))
best,
chris
Old 02-28-2021, 08:47 AM
Puny Bird
Mark Henry's Avatar
Originally Posted by boyt911sc View Post
Mark,
Was this a typo?
Tony
Likely spell check or because I was using a tablet or my phone and didn't notice the mistake.
Old 02-28-2021, 10:01 AM
