Turbofrog
smurfbus's Avatar
Best tricks to remove RMS? Screws or picking?
I have removed smaller ones with screws and then wedging the screws but this is a bit more delicate environment. The RMS that I want to remove has a aluring in the middle, black outer and orange inner ring.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 04-22-2021, 03:48 AM
Puny Bird
Mark Henry's Avatar
Get a cheap seal puller/prybar and grind the hook to fit nice, I back it up with a flat bar so I don't mar anything I'm prying against.
The part you grind you want to round over and deburr smooth so it can't scratch anything, like the seal surface.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 04-22-2021, 03:45 PM
Here is a pic from a 964 crank for an engine I rebuilt.
The previous tech had damaged the sealing surface when removing the seal.. this is what you want to avoid.
Personally, I'm comfortable drilling a short hole, inserting a self tapping screw, and using a puller or even a claw hammer to prise them out.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 04-23-2021, 06:38 AM
