brandett's Avatar
Question Alternative to Curil-T
Curil-T is not sold in Sweden
I can get it from Germany but the freight of €20 for a €8 tube does not make me happy.
Does anyone have alternative suggestions on what i can use instead ??
It´s my hobby.
911 SC -82 coupe.
My Project
Old 05-08-2003, 05:09 AM
Senior Member
Doug Zielke's Avatar
Hi Peter,
Three-Bond 1104 would do the trick. Around here, it's available from m/c shops.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 05-08-2003, 07:25 AM
brandett's Avatar
Not my day, seems like Three-Bond is another product/manufacturer that thinks sweden is to small to make it worth being present...
But thanks for the suggestion
It´s my hobby.
911 SC -82 coupe.
My Project
Old 05-08-2003, 08:08 AM
brandett's Avatar
Well, i believe that porsche engines are rebuild in a proper way in sweden by professional people, and they must use something else than Curil-T ( I am not one of the professionals )
The search will continue ! I will post the result here. Heck for €30 i get a pallet of goods from Germany each week...
It´s my hobby.
911 SC -82 coupe.
My Project
Old 05-08-2003, 08:19 AM
brandett's Avatar
Well after some calls to Germany i found two distributors in Sweden and were able to get hold of it. Both distributors has websites, but none of them had the product visible, ie not showing on the Google search.... Calling around tho shops did not help either...
Finally, i called my local dealer who after getting the distributors name, placed an order for one (1) Curil-T to me So if you need Curil-T in Sweden, give me an mail, i can save you some time..
It´s my hobby.
911 SC -82 coupe.
My Project
Old 05-09-2003, 03:08 AM
Senior Member
Zendalar's Avatar
Curil-t...what does it do? Isn't there a Loctite or Wurth product that would do, those are available in Finland, so I would presume that Sweden has those too.
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 05-09-2003, 05:59 AM
brandett's Avatar
Page 129 & 130 explains the use
It´s my hobby.
911 SC -82 coupe.
My Project
Old 05-09-2003, 06:03 AM
Senior Member
Zendalar's Avatar
Engine rebuild book ? Well I don't have it handy (still at work and book is at home), but it sounds like threadlocker, Loctite has the same. If its some sealant between case halves and such, i used this orange goo, that has a word "green" in its name.
Projects:
Old 05-09-2003, 06:13 AM
Irrationally exuberant
ChrisBennet's Avatar
Curil-T is a non hardening high temp sealant. It isn't used to seal the whole case just #8 bearing.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-09-2003, 06:30 AM
Author of "101 Projects"
Wayne 962's Avatar
Curil-T is what I recommend for a good, general-purpose sealant when you want an extra degree of assurance on seals. It's usage is almost always optional, but it certainly does help stop leaks...
-Wayne
Old 05-09-2003, 01:53 PM
Banned
snowman's Avatar
Ford has a similar sealant, non hardening, high temp, very cheep and just as good.
Old 05-09-2003, 10:03 PM
