Porsche 911 S 1972 strange engine numbers
Hi,
Bought a 1972 911 S I purchased it in the states and it was new delivered in Washington…. That’s the only history I got with the car …. Previous owner is a dealer and he has sadly no history anymore…..It has widened front and rear wings and a huge RSR rear tail and looks like a race car ….
The engine number 632xxxx 911/53 is matching with the car but it sits on Weber carbs.
When opening the engine I discovered 92 mm Arias pistons, 38 mm intake ports on cylinder heads, con rods reworked to maximum piston height, balanced crank, rods etc
I had all the parts cleaned and blasted and discovered some strange inscriptions in the engine block on the flywheel side in neighborhood of the mechanical injection mount.
It states following:
COMP 8477 B 010
Does this relate to the engine builder? And if so anyone an idea who built it and what are the specs.?
Thanks,
Old 07-18-2021, 04:34 AM
BURN-BROS's Avatar
The numbers stamped on the case are from the machine shop.
Competition Engineering
8477 is the job number
B 010 is either align bore amount or the amount they took off the spigot to cylinder mating surface.
Old 07-18-2021, 06:58 AM
many thanks 🙏
I just asked them now for more info what was just done to it…. Hopefully I can extract also some more history on the car
Old 07-18-2021, 08:46 AM
