Aluminium or Mag case- how do you tell?
Hello,
Can somebody tell me how to tell if a case is Alu or mag, engine number starts with 614 Thanks
David Sweden 914 76 912 66 |
Engine type number is a good method. Using serial number, Typically, the 3rd digit is model year. So 1974... mag case.
Aluminium is not dark grey like magnesium.
Lyndon |
Put a photo up will tell you
Find a non important spot on the case, scrape some material off and light ,if it burns it’s a mag!
Here is my history of the early 911 engine case revision history:
https://www.early911sregistry.org/forums/showthread.php?63809-911-engine-case-Revisions The earliest aluminium cases (65-68) had the serial # facing the rear. Then the magnesium cases had the serial # facing to the right. Late in the Mg period there were a few Al cases with 7R but these were for the RSR, and a few RS; so very rare. The later aluminium cases from 1973 on, no longer had 901 prefix casting part #'s (below the oil return tubes) and instead had 911 or 930 prefixes. It literally takes seconds to tell the cases apart.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
DJ - don't you mean from '74 on? '74-77 were the mag case years for the street models, no?
Functionista
First street 911 mag case was 1969. Porsche won some type of award for the casting of it.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Heavens no, the first Mg cases were in production for the 1968 Model year, and probably during Dec 1967. I have actually laid my hands on one prototype Mg case that was built into a test engine for a 1969 911S type 901/10 before the original aluminium case engines ceased production. All 1969 production were Mg cases.
Ah, right. Brain failure
I would rather be driving
put a drop of vinegar in a discrete area. Magnesium will bubble. Aluminum will not.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
