Harpo's Avatar
Originally Posted by Lyndon302 View Post
I will strip it down Monday.
It has timing chains that are linked. Also the pistons/ rings are not ideal. ( Was done at the peak of covid and I had to compromise )
This is a good excuse to part the case plus I have some goodies in the house.
Lyndon
Where did you get your straight cut gears? Brand?
Old 08-05-2021, 03:46 PM
Jon at EBS
Pauter same as the the rods.
Lyndon
Old 08-05-2021, 04:12 PM
Update
I'm sure now it's rod bearing that's in the filter.
They are worn. So I'm glad it's apart.
I will get the crank measured. Then I'm using ACL rod bearings. I can get STD. 001 over and 001 under in race spec. Locally made.
The right price as well. Speaking to the guys in Tassie they have made bearings ( one off which they don't supply ) for a mob in the USA.
So some Porsche parts in the USA are rebranded ACL.
Old 08-06-2021, 12:24 AM
Old 08-06-2021, 01:28 AM
ACL make great bearings.
BTW, your workspace is fantastic. Wish I had it.
Mike
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 08-06-2021, 05:24 AM
Harpo's Avatar
Jon at EBS
Lyndon
Thanks, just ordered mine
Old 08-06-2021, 07:41 AM
In a street car you might want to reconsider straight cut ims gears are quite
noisy
Old 08-06-2021, 04:43 PM
I saw the edge of that gear looks like it was rubbing on something could that be where the aluminum flakes came from ?
Old 08-06-2021, 05:55 PM
noisy
Can't be noiser than the transaxle
Old 08-06-2021, 07:46 PM
The gear is good. One tooth has been squeezed by something against the steel gear. Old issue. Definitely it's flakes from the big ends.
Old 08-06-2021, 10:03 PM
Lyndon, are you still thinking it's flakes from the big ends? If the flakes are tough and metallic, do you unfortunately have the chips missing from the crank and bearing structure? The pictures you've shown seem to to show the rod bearings with some soft layers still intact, I think the worse area's show copper.
Phil
Old 08-10-2021, 08:34 AM
