Where did you get your straight cut gears? Brand? Thanks David |
Jon at EBS Pauter same as the the rods. Lyndon |
Update
I'm sure now it's rod bearing that's in the filter. They are worn. So I'm glad it's apart. I will get the crank measured. Then I'm using ACL rod bearings. I can get STD. 001 over and 001 under in race spec. Locally made. The right price as well. Speaking to the guys in Tassie they have made bearings ( one off which they don't supply ) for a mob in the USA. So some Porsche parts in the USA are rebranded ACL. ![]() ![]()
ACL make great bearings.
BTW, your workspace is fantastic. Wish I had it. Mike
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
In a street car you might want to reconsider straight cut ims gears are quite
noisy |
I saw the edge of that gear looks like it was rubbing on something could that be where the aluminum flakes came from ?
The gear is good. One tooth has been squeezed by something against the steel gear. Old issue. Definitely it's flakes from the big ends.
Phil |
