DavidSwedem's Avatar
Aluminium or Mag case- how do you tell?
Hello,
Can somebody tell me how to tell if a case is Alu or mag, engine number starts with 614
David Sweden
914 76
912 66
Old 08-03-2021, 10:10 AM
Engine type number is a good method. Using serial number, Typically, the 3rd digit is model year. So 1974... mag case.
Old 08-03-2021, 11:41 AM
Aluminium is not dark grey like magnesium.
Lyndon
Old 08-05-2021, 06:26 AM
Put a photo up will tell you
Old 08-05-2021, 08:23 AM
Find a non important spot on the case, scrape some material off and light ,if it burns it’s a mag!
Old 08-05-2021, 03:47 PM
djpateman's Avatar
Here is my history of the early 911 engine case revision history:
https://www.early911sregistry.org/forums/showthread.php?63809-911-engine-case-Revisions
The earliest aluminium cases (65-68) had the serial # facing the rear. Then the magnesium cases had the serial # facing to the right. Late in the Mg period there were a few Al cases with 7R but these were for the RSR, and a few RS; so very rare.
The later aluminium cases from 1973 on, no longer had 901 prefix casting part #'s (below the oil return tubes) and instead had 911 or 930 prefixes. It literally takes seconds to tell the cases apart.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 08-06-2021, 05:25 AM
Walt Fricke's Avatar
DJ - don't you mean from '74 on? '74-77 were the mag case years for the street models, no?
Old 08-10-2021, 12:14 AM
Functionista
manbridge 74's Avatar
First street 911 mag case was 1969. Porsche won some type of award for the casting of it.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 08-10-2021, 02:32 AM
djpateman's Avatar
Heavens no, the first Mg cases were in production for the 1968 Model year, and probably during Dec 1967. I have actually laid my hands on one prototype Mg case that was built into a test engine for a 1969 911S type 901/10 before the original aluminium case engines ceased production. All 1969 production were Mg cases.
Addicted since 1975
Old 08-10-2021, 07:07 PM
Ah, right. Brain failure
Old 08-10-2021, 08:32 PM
I would rather be driving
jpnovak's Avatar
put a drop of vinegar in a discrete area. Magnesium will bubble. Aluminum will not.
Old 08-11-2021, 02:01 PM
