Valve spring question
2.0L 67
Are the valve springs progressive. I've read they are and a proper install is required.
I cannot see this on my springs.
Eg anyway will do ??
Thanks lyndon
Old 09-22-2021, 05:26 PM
abit off center
cgarr's Avatar
yes they are, the tight wind is against the head.
______________________
Craig
G2Performance
Old 09-23-2021, 03:24 AM
Im having difficulties in seeing a tight wind ??
Lyndon
Old 09-23-2021, 04:40 AM
Arlo911's Avatar
Normally the tighter wind is pretty easy to see. Maybe try to post a picture?
Old 09-23-2021, 07:51 AM
abit off center
cgarr's Avatar
Take a 1/4” drill bit and spiral it to each end you will see the difference
Craig
G2Performance
Old 09-23-2021, 03:07 PM
Now that makes sense
Lyndon
Old 09-23-2021, 03:14 PM
Yep it's progressive.
Learn something every day.
So easy to see once I used the drill bit and marked it.
The white mark nearest the bottom is the bottom when installing.
A side note I can't find any info on spring fitment in Wayne's book
Thanks again
Lyndon
Old 09-23-2021, 05:15 PM
abit off center
cgarr's Avatar
what do you mean fitment? installed height?
Craig
G2Performance
Old 09-23-2021, 05:58 PM
No about the spring orientation
Lyndon
Old 09-23-2021, 05:59 PM
