Valve spring question
2.0L 67
Are the valve springs progressive. I've read they are and a proper install is required. I cannot see this on my springs. Eg anyway will do ?? Thanks lyndon |
abit off center
yes they are, the tight wind is against the head.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Im having difficulties in seeing a tight wind ??
Lyndon |
Normally the tighter wind is pretty easy to see. Maybe try to post a picture?
abit off center
Take a 1/4” drill bit and spiral it to each end you will see the difference
![]() Sent from my iPhone using Tapatalk
Now that makes sense Lyndon |
Yep it's progressive.
Learn something every day. So easy to see once I used the drill bit and marked it. The white mark nearest the bottom is the bottom when installing. A side note I can't find any info on spring fitment in Wayne's book ![]() Thanks again Lyndon |
abit off center
what do you mean fitment? installed height?
No about the spring orientation
Lyndon |
