^^^ good setup. As far I can tell also the orifice dimensions come from the aviation world. IMO the "spec." is not very exact but probably good enough. One might think a chart or table of flowrate and delta pressure exists somewhere but as mentioned what they have now is good enough.
Sold: 1989 3.2 coupe, 112k miles |
The spec for the orifice size is in the FAA regs.
"For an engine cylinder having less than a 5.00-inch bore; 0.040-inch orifice diameter; .250 inch long; and a 60-degree approach angle." The approach angle and length are critical for comparisons between two different leakdown testers. |
To close this out. Buyers never asked about a compression test after seeing the leak-down test. So I didn't retest with a hot or warm motor. Car sold. Issue is resolved.
