Just READ my lines above .... it depends on the incoming pressure. If you apply 7 or more bars then you almost everytime end up with values below 10% which gives you -nothing- but nice looking numbers below 10.
Or do you think Hazet as one of the best tools manufacturer just sets wrong areas on their gauges to green? I dont think so.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
Racer
At 50 psi or 100 psi, 20% leak down is too much for an air-cooled 911. The last time I did a leak down on my race engine, which was just a few weeks ago, I has the same leak down percentage at 50 psi and 100 psi......
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Shure, because your setup (I guess) comes with two gauges where behind the first one an orifice keeps the internal prassure at a given level no matter what pressure comes in. Cheap Chinese ones internally even go down to 1 Bar. These even go up to 40% in their acceptable range. Watch the Sets shown in the www.
All depends on the actual pressure present in the combustion chamber. Use a one-Manometer setup where you can set the an individual pressure at the output reaching the chamber and you will have diff. percentage results at diff. incoming pressures. So a "20% is too much" answer is valid for your leak down test set and many others out there but not a rule of thumb in general. Btw I personally also prefer a maximum here of 10% at 4 bar but ... thats my personal limit before I suggest an engine overhaul. But main focus is - as said - that rleak down esults within the cylinders are almost matching.
I try to be careful about things where I am not entirely certain. Aircraft mechanics use these things where there are more consequences if you don't get it right, and OK an engine which didn't actually meet FAA or someone's specs. Maybe someone with that experience will chime in.
A quick look at testers which are for aircraft shows plenty with two dials (though many also have two valves - don't know what those are for). Aircraft testers seem to denominated by the diameter of the piston, also. From previous discussions about leakdown testers, I think the way they work - the two gauge ones - is that between the pressure you regulate for dial A, there is a small orifice leading to dial B. Because it is so small, negligible air flows/pressure is lost to dial A when dial B is connected to a cylinder. I analogize this to the tiny orifice in a CIS fuel distributor through the large diaphragm separating the top and bottom halves of the FD. Or perhaps to a high value resistor which doesn't draw enough current from a circuit to lower its voltage? High impedance on volt meters in these days of good and inexpensive electronics (from one who grew up in the VTVM era)? Beyond some level of impedance, only for the most exacting scientific testing would more be better in practical terms. My experience (all random) with air leaks is that if there is an opening, even if very small, near negligible pressure will show up in a soap bubble test. Maybe a rubber seal might work differently, as more pressure might force a seal to leak. But I don't see that kind of concern with engine leak downs. You aren't going to force valves off their seats, and my suspicion is that you won't move rings to where they don't seal as well. Past discussions often involved the size of the orifice, and on how there was thought to be no standard for it. With my first compressor, I couldn't get 100 psi on the inlet side, so used 80, or 50 to save the math, just like many others have. Now I can use 100, so I do. My take on how Hazet has set up the one dial gauge is that its face is set to work properly only at a very specific inlet air pressure. It must still have a restriction between the inlet and the outlet. I suspect the adjustment knob is set so the one gauge is at 0, and its face is calibrated so 0 is for what their desired inlet side pressure is. It seems to me that higher pressure just gives better analog dial resolution. Soon, I suspect, there will be electronic digital dials on the market - I just bought a digital tire gauge. Hard to know what its error range might be - anyone who has compared the several tire gauges we all collect has been a bit surprised to see how much they all vary. As mentioned, the gauges on my leakdown tester are quite probably not up to some technical institute standard of accuracy. So I am not understanding the argument about why one and only one inlet pressure can work on a two gauge system, though it is critical on a single gauge system. Unless it has to do with internal orifice size. And it would seem that with a dual gauge system you could deal with that - after setting up the test, reset the inlet pressure so the inlet side is back to 100 or whatever you had chosen, and promptly read the outlet gauge. I'd be leery about 20% leakage in an exhaust valve - if seat or valve is burned, it could get worse fairly quickly. Ring blowby you could live with for a while - maybe more frequent oil changes? Intake, I'd wonder why. But for a race or track motor, I'd not settle for 20% anywhere. After blowing up a 2.7, I got a used replacement, with leakdowns in the 10-12% range per a mechanic with a big, fancy looking test rig. He said it should be OK, just not quite as fresh. I ran it a while, but persuaded myself that my lap times were suffering, and sold it - with full disclosure - to another racer. He said it worked fine for him until he built a 2.8 with carbs and cams and CR etc. So Andrew, I think you will have some trouble convincing some of us (most of us aren't worried about being corrected - that's how you learn if you accept the fact that there is almost always someone out there who knows more than you do) that the the inlet pressure on a two dial tool will cause the percentage of leaking to vary if you operate it in the normal way. |
A healthy engine should be under 5%.
When I tested my 964 engine I had leak down at 1% (could not hear any leaks at all), on the same tester we did a friends 968 turbo, set up with larger ring gap. It had 15+ something, mostly leaking through the rings.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
If I got 20% on a daily driver with 300k miles on it, I may be OK with that for now but I would be planning on replacing/rebuilding the engine. I built my own leak down tester with parts I bought from the local hardware store. ![]() I've posted this picture before and I keep using it. |
@ Otto
Read my explanation further above, ... it depends on the pressure which reaches the combustion chamber. The Manufacturer Hazet of the tool above deals with an internal clamped pressure provided to the combustion chamber and thats why here "these" 20% are within the range. Many people go with about approx 7 Bar at the combustion chamber when doing a leak down test there YES about 5% is ok and should not be exceeded. BTW, YES, your gauge output is fully ok at approx 80 PSI. What is the sice of the ofrice you used on your DIY seutp? Nice btw! Here's a reading I did a few weeks ago ... approx 2.5% loss when applying 4 Bar to the comb.chamber. Same very slight Noise on all six tests.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 09-28-2021 at 02:44 AM.. |
Aircraft piston engines are measured using the two gauge leakdown tester, but the readings are listed as "compression tests," with the post orifice number listed first, then the inlet air. A reading would be advertised as, "Compression is 78/80." Even though we all know it's actually a leak down test.
At the risk of throwing too big a wrench in the works.....
I was thinking... what we are trying to measure is an amount of air flow at a given pressure (80-100? psi) applied to a cylinder. The pressure applied to each cylinder should be the same. If that's the case then why isn't the downstream gauge set to read a constant pressure? What would happen is the gauges would read 105-100 instead of 100-96 or something like that. I know it's a small difference and probably not worth worrying about.
Sold: 1989 3.2 coupe, 112k miles |
Racer
No, you are measuring pressure difference. If the inlet pressure is 100 psi and the cylinder hold 95 psi, there is a 5 percent difference or leak down. I use a 2 gauge setup with one gauge showing the inlet pressure and the other showing the cylinder pressure.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion Last edited by winders; 09-28-2021 at 07:59 AM.. |
ugh.. the FAA has some guidance of leak down tests https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/AC_43.13-1B_w-chg1.pdf page 8-7 I built my tester 20 years ago and I think I just put a plug of epoxy in the pipe nipple that is in between the two gauges and let it cure and then drilled a hole with a .040" drill bit. The FAA recommends a .040" orifice for engines with pistons 5" diameter or below and .060" for engines with pistons bigger than 5" diameter. |
Your engine is good and you should be jumping with joy at getting those leak down readings. Those are very good numbers. You will have to find something else to worry about. Small variations in upstream line pressure from your compressor won't matter. I try to keep the test between 100 and 80 psi. My compressor maxes out at 100. |
Andrew - first off, why is the pressure which reaches the combustion chamber anything other than the regulated pressure before the orifice, minus what leaks out? We both know that if the filter in a WUR is blocked so the WUR can't reduce the CP, the CP ends up the same as system pressure. And if the line from the WUR to its next stop is blocked, you get the same result. If you have zero combustion leaks, you will have no difference between the two gauges, without regard to what the regulated pressure is, won't you? And with zero leaks, the orifice diameter won't matter, will it? Of course it will, some, when connected to the spark plug hole.
Second, how do you respond to the argument that the Hazet, which has to make things work with one fixed gauge with a "backward" face so it reads directly in percent, has to use a very specific regulated input pressure for their system to work? Certainly, if you used more or less pressure than specified, you'd get different readings (though you couldn't really use more -the needle would hit its stop). More to the point, Hazet says you need an air pressure source of 6-12 bar, so their setting pressure can't be over ~90 psi. If you somehow measured what the regulated pressure is when set is 80 something psi, I believe you. My suspicion is that the gauge they use isn't custom made for them, though they have a custom face. Perhaps some gauges available in metric countries are specified at 5 bar? Two gradation lines difference between cylinders they say are 4% loss, which they say is acceptable if that is the greatest variance between the high and low cylinders. You set the pressure until the dial pointer is on 0. Then they say green area is up to 23% on the gauge. Like others, I am mystified at accepting a 23% leakage. If I had a 19% leakage in five exhaust valves, but 23% in one, would I do more than, say, chance driving home or to a shop for a rebuild? If I had my car home, I'd perform a 50 psi and a 100 psi leakdown test, to see if that confirms that (within the differences in resolution) the % results were the same. And am I wrong to analogize pressure to voltage, and flow to current? The Ohms law analogy does suggest that different orifice sizes will lead to different leak percentages, though, if the orifice is taken as the resistance. However, we are measuring a whole circuit - the leakage from the cylinder is part of the circuit - maybe that makes orifice differences, at least if small, not as R1, and the leakage as R2. Resistance electrically is additive. Here we have the area of a 0.04" diameter orifice , R2 is infinite, and R1 is irrelevant. If we assign a small enough decimal number to R1, and some rather lower number to R2, would that work? It appears that the length of the restrictor, as well as its diameter, affects the pressure drop. That is a term in the equations doctors use in figuring blood flow drops, which are pretty much like Ohms Law with some special cases. But maybe the length, if relatively short, doesn't matter all that much? I have never seen an engineering analysis of the length, compared to the diameter, of a dent in, say, an oil line in terms of flow. |
If you have a tester with only 1 gauge, like the Hazet, it is dependent on the air source to be the "other" gauge and pressure regulator.
Its the orifice between the unrestricted air source and leaking chamber that do the magic in the test, it needs to be appropriately sized to the leakage of the piston rings. Its the only thing that can skew the test. If you have a tester with a red/yellow/green zones and percentage instead of numbers you need the specific air pressure that the manufacturer of the gauge specifies. The Hazet pictured seems like a cheaper to manufacture and dumbed down tool.
As you already know (as thats what you meant above), when just connecting a simple gauge shurely different incoming pressures will end up in diff. results. Quote:
FAA following devices are shurely a way to go, ... but beside other FAA compilant ones I also built myself one DIY version of a tester which does not come with an ofrice as by this I can provide the Full 8-10 Bar to a combustion chamber, wich not only once showed me that there is a "leak" between the Head and the cylinder. Covering that area with some dishsoap/water mixture showed me in that particual case that ateh sealing ring was flawed – which was prooved when the engine was taken apart. Quote:
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 09-29-2021 at 03:33 AM.. |
All leakdown testers MUST have an orifice/restrictor between the air source and combustion chamber otherwise you can't measure a pressure drop.
Just do a test: Take a one gauge device with no ofrice and set the inpout pressure to exactly matching 4 Bar while the output is closed/sealed. If then connecting the output to the combustion chamber the leak in the combustion chamber will show the proportional pressure drop on the gauge. I did the test often and the result is exaclty matching to the ofrice containing Hazet device with 5-8 Bar applied to its input. The logic is simple ... i.E. Walt compared it to the WUR pressure affecting approach.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 09-29-2021 at 04:54 AM.. |
yup ...
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
