It's a 914 ...
Sounds like you’re getting good help and advice and taking the right steps.
Re: rod bolts, I realize I wasn’t asked, but I wouldn’t look at that so much as a “while you’re in there” thing as much as a preventive measure to avoid a failure of a known weak spot for the 3.2 engines. A thrown rod is the outcome you’d be risking, and when that happens you’re usually looking at replacing half of the engine to fix it. Case, crank, the failed rod, the piston that was attached to it, rebuild/replace the head to start. Plus whatever collateral damage. Rod bolts are pretty cheap. |
abit off center
The intake valve stems are way out of spec, something we see a lot in these motors.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
With your new pistons, please check piston to cylinder clearances. If you don't have the tools to do it, send it out to a local machine shop (does not have to be Porsche/Euro specific) to measure them for you.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Brew Master
I should have mentioned that. John Walker told me to do check that when I was considering installing the "new" pistons. It was done.
Nick |
Good afternoon Cabmando - what cam did you end up choosing to fit on your rebuild?
Regards, Steve |
Brew Master
After doing a lot of research, I decided the stock cam was sufficient. I just couldn't find the benefit for the cost associated with new cams.
Nick |
I was hoping you’d go with the 993ss and report the results!
Otherwise looking forward to seeing the results of your rebuild. |
Thread Tools | |
Rate This Thread | |
