Better Cam option
Currently looking for a better cam option for my low hour 2.0. race engine. Well put together , but under cam'd race engine. Currently Web 120/104.
I currently also have a 134/135 or 171/149 options on shelf. Looking for a little more top end, which means above 7-8k power.
I know the 134/135 is basically a 906, but curious about the 171/149 in small displacement motor. The other concern is pretty big valve lift difference 120/104 Vs 133/135. The other option lift is very close.
Old 11-22-2021, 03:22 PM
Jeff Alton's Avatar
Have you spoken to Web about your engine goals?
Also drop a note to John at DRCamshafts (he posts here) to see what he thinks.
Cheers
www.turn3autosport.com
Old 12-01-2021, 11:51 PM
It's a 914 ...
stownsen914's Avatar
As Jeff said, give Web a call. Seeing as you have several of their grinds on hand, they'd be a good one to talk to see which would best fit your application.
Old 12-03-2021, 06:27 AM
