Also Tony I was trying to contact you per a suggestion from another user to see about having you rebuild my WUR/fuel head but for some reason the PM function, etc is not working. |
Schleprock
FYI to those planning to re-plate Nikasil cylinders (edit) and possibly plate Alusil cylinders (edit). I received this email back in May 2021 from US Chrome:
A Message To Our Dealers Looks like that dealer-only approach remains for 2022. Their pricing schedule on the website says so https://www.usnicom.com/plating/pricing And always make sure you know what the proper finished surface roughness must be and confirm the dealer relays it. Don't assume the plating vendor will know.
Kevin L '86 Carrera "Larry" Last edited by KTL; 01-27-2022 at 07:41 AM.. Reason: Added mention of plating Alusil cylinders |
garagejdm,
At first reading Bentley repair, quote "if equipped with Alusil pistons and cylinders, replace with Nikasil" and after counting the number of fins etc.., darn I have Alusil. Now I'm thinking I was lucky to have the Alusil, supposedly less wear longer lasting. If there was a problem, new cylinders and pistons, I'd skip re-plating, unless economy was an issue, I haven't looked lately, but I remember last year the euro spec cylinders and pistons were something like 4k a set, not bad, the u.s. version were getting up there $6k, but I wonder how many have worn out alusils. Phil |
I do a lot of plating and have some nikasil recipes been trying to talk myself out of doing it. Green silicon carbide in 3 micron is not too cheap and some of the other ingredients are just a little nasty to have around the house. Have not priced a diamond hone either but I’m sure sticker shock would be in order. But it would be nice to be able to plate your own cylinders. |
