Rebuilt Engine needs to site for 6-9 months
Guys
What’s the recommendation for a newly rebuilt (everything !)
It must sit for 6-9 months before installing as restoration of body continues
What should be done to keep fresh and no oxidation or damage
Gold71
Old 12-17-2021, 03:17 PM
6 months is nothing in the big scheme of things. If you're really worried about it, make sure that no moisture or critters get into the intake or exhaust by covering the openings with plastic and sealing with tape. Remember to take them off before first start, and as always, crank the engine over without ignition until you have oil pressure.
Old 12-18-2021, 05:28 AM
Thanks, should I shoot some oil into cylinders and hand turn every few weeks ?
Gold71
Old 12-18-2021, 07:27 AM
E Sully's Avatar
You could consider using engine fogging oil. Should cling to the walls better than oil.
Ed
1973.5 T
Old 12-18-2021, 12:05 PM
Puny Bird
Mark Henry's Avatar
No, turning will wipe off the assembly lube.
You can remove the spark plugs and give it a quick shot of Quicksilver marine engine storage spray.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 12-19-2021, 04:26 AM
It's a 914 ...
stownsen914's Avatar
Hopefully whoever rebuilt it put the right lubes in the right places and it shouldn't be a big deal as long as the engine is properly stored until it's ready for use.
Old 12-19-2021, 06:19 AM
