It's a 914 ...
Smoothing/radiusing sharp edges on aftermarket pistons
What’s the current thinking on smoothing/radiusing edges on aftermarket pistons like JE and CP? Seems like it makes sense to at least knock off the sharp edges around the valve pockets. How far do folks take this? My application is a track engine 12:1 compression.
A couple threads I found on the topic: https://forums.pelicanparts.com/911-engine-rebuilding-forum/452068-sharp-edges-je-pistons.html https://forums.pelicanparts.com/911-engine-rebuilding-forum/368320-jugs-slugs-confessions-je-piston-owner.html
Functionista
Using cams with any overlap? Then I’d certainly follow Henry’s advice in the second thread you listed.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
For the same reason for attending to the spark plug hole and threads.
The sharp edges can be a tremendous hot spot in the combustion chamber. It is paramount to mitigate all possible hot spots , Then you can rely on the twin plug to do it's job reliably and consistently . Attend to ALL SHARP EDGES. Just my thoughts Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Navin Johnson
Debur the valve pockets, and massage the top of the valve pockets at the piston crown.
![]() or you can use a dremel or die grinder..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
