Guidance on cams : 3.2 build - Twin Plug, 10.5, PMOs
Building a 3.2 with twin plug, PMOs and 10.5 CR. Going into my 1970T.
Ive seen guidance on other 3.2 builds but have not yet found such on this particular build. Running SSI and a Sport Dansk muffler. Have those on hand. Much appreciated ! |
I would contact Dema Elgin or one of the other reputable camshaft grinders like DRC, Web, and give them your specs. They will recommend the proper grind for your application based on your build and intended use ( Track, street rod, occasional auto X ) . I have a similar build with Webers and I went with the Mod S grind from Elgin.
Howard
'77 1973 911RS Backdate, 2.7 liter w/webers '70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress '75 911 RSR street car in progress '77 930 Replica '75 993 GT2 EVO race car , 3.6 TT '79 928 5 speed money pit in progress Last edited by pocv0; 03-31-2022 at 01:43 PM.. |
Yes. Will call Dema for one. He did my 964 cams.
The 120/104 cam from WEBCAM is a super profile for a 3.2 build. Real strong and willing all over the powerband.
My 3.2 short stroke has that profile and puts out 290ps and 336,5Nm 254 ft/lbf Sent from my iPhone using Tapatalk |
(man/dude)
I'd email John at Dougherty Racing Cams. He contributes his knowledge to this forum often.
Guessing he'll steer you towards DC43-102 or DC44-102. You'll probably need to upgrade valve springs. Good luck!
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Don’t count out William Knight. I’d definitely be in contact if I had a similar build.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Try not, Do or Do not
What is the intended use/purpose of your end product? What is the minimum octane of the fuel you will use? At 10.5:1 your dynamic compression becomes critical. Even with twin plug, these engines have the propensity to detonate. If your plan is to run street gas, 10.5:1 is too high for most street friendly cams. Given the fact that you are using SSIs, your high rpm potential is limited. With the 3.2 short engine, we generally expect the potential horse power to be around 260 @6800. Given those numbers, we like the DC60. It's fun to drive, offers low enough dynamic compression to mitigate detonation (not eliminate the potential) and leaves a little on reserve if you choose to transition to a more appropriate exhaust system.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry, thanks for the note.
Street motor. Hill country driving in Texas. 93 octane. I was not originally thinking Short Stroke but have access to another crank. I wasn't really thinking high rpms. More low end. What exhaust would you recommend instead of the SSIs, Henry ?
Robert Callaway PCA | Early S Registry | R Gruppe 1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S 1962 S90 Coupe - Gone, but never forgotten... 1985 Targa - A distant memory... |
