Following this build!
Out of curiosity why not go with pauter rockers? They're something like 1.5lbs lighter in all
Instagram.com/timofthevalley |
Except they aren’t anywhere near the 85g they advertise. I bought a set…….. significantly heavier than advertised.
Well that's lame
Has anyone contacted them about that?
Anything new Sirac? I have a 77 2.7L and I am looking at this build enthusiastically.
1977 911S - high mileage and a bit rough but mostly original. Soon to become a bit of a hot rod. |
Not too many updates but here’s where I’m
At for now. ![]() Installed a billet oil pump screen cover with clearance for the later oil pumps ![]() Installed the Clewett cam sync to match with my EFI ITBs ![]() Installed the fresh oil cooler. Had to clean out the inlet since they left some sand in there. Always check others work. ![]() Mocked up the Burch headers. Not happy with the fit. The heater boxes interfere with the valve cover studs. Working with them on a fix or replacement but it’s been slow. ![]() Mocked up and trimmed the Sheridan shroud. It’s an okay fit, but wish I spent a little more for a better fitting kit with it pre-trimmed. ![]() ![]() Mocked up the Throttle bodies from Clewett. I will be experimenting adapting a drive by wire motor. ![]() 3d printing the drive by wire motor adapter before I send it off to get cut. ![]() That’s where it’s at for now. It’s all sealed up and I’m focusing on the body. Stripping it down to prep for sand blasting. |
Thanks I appreciate it. Love the amber shrouds and engine surround. I am thinking of DIY pre-preg carbon/kevlar experimentation on forming a shroud and surrounds.
If you do make one in carbon Kevlar I’d be interested |
