Following this build!
Out of curiosity why not go with pauter rockers?
They're something like 1.5lbs lighter in all
Instagram.com/timofthevalley
Old 10-04-2023, 11:41 AM
Evan Fullerton's Avatar
Except they aren’t anywhere near the 85g they advertise. I bought a set…….. significantly heavier than advertised.
Old 10-04-2023, 01:24 PM
Well that's lame
Has anyone contacted them about that?
Old 10-04-2023, 01:42 PM
Ace of Spades
Anything new Sirac? I have a 77 2.7L and I am looking at this build enthusiastically.
1977 911S - high mileage and a bit rough but mostly original. Soon to become a bit of a hot rod.
Old 10-14-2023, 09:09 PM
Not too many updates but here’s where I’m
At for now.
Installed a billet oil pump screen cover with clearance for the later oil pumps
Installed the Clewett cam sync to match with my EFI ITBs
Installed the fresh oil cooler. Had to clean out the inlet since they left some sand in there. Always check others work.
Mocked up the Burch headers. Not happy with the fit. The heater boxes interfere with the valve cover studs. Working with them on a fix or replacement but it’s been slow.
Mocked up and trimmed the Sheridan shroud. It’s an okay fit, but wish I spent a little more for a better fitting kit with it pre-trimmed.
Mocked up the Throttle bodies from Clewett.
I will be experimenting adapting a drive by wire motor.
3d printing the drive by wire motor adapter before I send it off to get cut.
That’s where it’s at for now. It’s all sealed up and I’m focusing on the body. Stripping it down to prep for sand blasting.
Old 10-15-2023, 09:30 AM
Ace of Spades
Thanks I appreciate it. Love the amber shrouds and engine surround. I am thinking of DIY pre-preg carbon/kevlar experimentation on forming a shroud and surrounds.
Old 10-15-2023, 07:38 PM
If you do make one in carbon Kevlar I’d be interested
Old 10-15-2023, 08:08 PM
