"Hot" cam choice for small port 3.0 with SSIs.
In an effort to avoid the slippery slope and preserve some capital I'd like to explore some rebuild options that are limited by my current intake and exhaust.
The car in question is a 1982 US spec SC. Small 34mm port heads with soon to be installed Weber 40 IDAs. I'm not opposed to doing some work on the heads(valve guides will need to be done anyway) provided the juice is worth the squeeze and the money wouldn't be better spent somewhere else. On the exhaust side I have SSI heat exchangers and M&K sport 2-1 muffler. These are the things I'd like to keep. The goal is pistons(close to stock compression, single plug) and cams that are able to take advantage of the carbs. Not a track car but I would like a bit more hot rod feel and power higher in the rev range, the car is mostly used for attacking back roads and mountain passes. I love the sound of the engine above 5,000rpm but not much is happening up there power wise. What would the "hottest" cam I could run giving the weber 40s, SSIs and not wanting to start changing rods, rod bolts, valve springs, retainers, rockers, etc, etc? Am I limiting myself too much by being unwilling to change the carbs, exhaust, or port sizes? Again, I'm desperately trying to avoid a soup to nuts rebuild. I'd like to make the engine incrementally better and save the big build and big bill until after the kids are out of the house.
_______________________________ 1982 911 SC 240,000mi and counting |
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Gt2 102 grind from DRC
it's not leaking....it's just marking it's territory |
I was thinking DC-40, so it’s good to know I’m on the right track. I’ve seen this mentioned a few times in my research. Seems like a small step down from the DC-40.
Yep, I'd go the MOD S style cam... and 9.5-10.0 comp. I think with the bigger cam your dynamic compression will be a little lower so you should be safe from knock.
With the cam advanced, torque down low was impressive. And pulled all the way past 7 happily. I've not had success with M&K mufflers... very limiting on an engine that flows well. Something custom and simple works better. Mine used a GT3 muffler.
Always learning. www.aircooledporsches.com.au |
How many horse power do you need at the crank to have fun?
If you are guessing , then you probably do not need as much as you think. I have 230hp at the crank and I can smoke just about any other similar displacement car, including a 2018 civic type r and a wrx sti 2018 in the 1/4 mile . 14.02 sec Theses specs with stock cis pistons and 34 mm ports I do not like the Gt2 102 grind from DRC, it is a cam for your grandmother. Mike I don't think you liked it either . Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 05-25-2022 at 08:05 AM.. |
Anyone have a graph of that? I have not seen one, and "historically" is a loaded term, as it is known that M&Ks have gone through iterations to address "issues" such as drone. Maybe Brian will weigh in. (I am not an M&K shill, but stating -15hp across the range necessitates some documentation. I'd rather not spend the $700+ if that is a fact).
Under the radar
I second Gt2 102 grind from DRC. Tons of midrange torque and response. Unless you are wanting power above 6500 rpm the GT2 will do the job. I was buzzing my limiter at 7500 rpm last sunday at an AX with those cams.
Also in order to go above 6800 rpm you will need racing valve springs with any hot grind. If it was me, I would open up the intake ports to something like 36-38mm. Not hard to do. Match with the manifolds. Otherwise your power will drop off above say 5500 with 34mm intakes. Oh, and by the way, I tried a M&K a couple of weeks ago. The drone was SO bad I took it off right away. Did not seem to hurt my power, though.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 05-26-2022 at 04:02 PM.. |
Why not email John at DRC???? Ask him what he thinks.....
It is what he does. We rely on him often. And he has made a couple of grinds specifically for our builds and we have been very pleased. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
This is true. I guess in a broad sense, one might think that "less metal" = "less dense".. but we know that isn't the case!
In my case, the M&K droned so bad, it gave me a terrible headache. First time I'd ever experienced this... weirdly, other people claim it's the best thing they've ever had and that their cars don't drone... I cannot begin to explain the difference in results... Brian tried to help by making me another set of tips with baffles in them. They did reduce the drone but the flow was so heavily impacted, the power was quite low. I sold the muffler to someone who ended up enjoying it, with no drone!
I started this thread with the hopes of getting some recommendations from people that have been down this path before and educating myself so when it’s time to talk to someone like John or if a great deal pops up in the classifieds I can be a more informed consumer. Thanks to everyone for their help so far.
It’s a 2 to 1 so there isn’t an issue with drone. I love the muffler but not if it’s costing 15hp vs ??? I wish Harry would return to the thread to give a little more insight. When it’s all said and done I’ll get the car tuned on a dyno and maybe I can take the muffler off between runs to get some actual data.
Not to hijack the thread, but what exhaust do you recommend for a SC 3.0 mild mod short stroke (Max Moritz 9:8:1) with a slight cam bump (M1) with SSI’s and early (‘79) CIS? I assume a 15 hp exhaust bump should benefit the original post question since that 3.0 has carbs and he’s looking for cam recommendations. The worst part of my ‘82 SC is that it “dies” at a little over 5k RPM - heck, my high mile Benz W210 OM606 diesel revs higher! |
Daniel
And despite what you may have read/heard about lead times, the last few sets we had John do were back to us before we needed them. Cheers
Call and ask John if the GT2-108 is right for your build. My engine is coming apart soon and I'm trying some top secret cams and my GT2-108’s are going to be available. Less than 10K miles.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
5200 rpm
Chassis Dyno graph shows a power loss centered at 5200rpm that may be what Henry is describing.
Engine is 3.2 SS 120/104 cams, 46mm pmo carb tuning, or M&K 2 in 2 out. Could be one or a combination of all above. Curious to hear others experiences with those cams with other combinations. They are very similar to DC 60, GE 60. The funny thing is everyone loved the feel of this engine. The kick from 5400 to 7000rpm was impressive but data would show it could be much faster eliminating that dip. Wish I had the opportunity to explore some changes.
Track: 91 C2 SuperCup wannabe, 08 Cayman S Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange |
