-   -   My new piston 3.0+ (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1120123-my-new-piston-3-0-a.html)
Old H2S 08-21-2024 01:02 PM
It will get to 330..
icarp 08-21-2024 01:06 PM
All numbers at the crank
Torque is, 267 lb/ft 3950 rpm and 272 lb/ft @4425 rpm and 270 lb/ft @4100 rpm and 267 lb/ft @5325 rpm, Thats 5lb/ft of variation in TQ over 1325 rpm
Also, 221 lb/ft @2100 rpm
More to come
Ian
Jpapgar 10-13-2024 02:59 AM
Still have sets avail.
Who wants to make some power
Axel84 10-13-2024 12:00 PM
You got pistons for the 2.0S 1969? And 3.4
Jpapgar 10-29-2024 06:49 AM
The 2.0 no
But we have sets for the 3.4 avail
Mixed76 10-29-2024 10:26 AM
More to come
Ian
78.5-80 lb-ft torque per liter is pretty solid!
Sent from my Pixel 7 using Tapatalk
KMoore68 10-29-2024 12:58 PM
I'm doing some planning around rebuilding my 2.7, would these new pistons be a good idea?
mikedsilva 10-29-2024 10:52 PM
Is there any value in using this design for a turbo engine build?
My 3.0sc engine is to be rebuilt using 964 crank and rods, and aiming for around 8.5;1....
Not sure if James can have a set custom made with correct pin heights etc?
icarp 10-30-2024 05:38 AM
Mike , this piston is designed to take advantage of the scavenge effect of valve overlap.
Hence the trough cut in the center of the piston.
With a turbo the best bet is the soft dome and sometimes a hollow in the center.
Forced induction makes up for the scavenge effect.
For all other NA 911 engines this piston is very effective .
Just my thoughts
Jpapgar 11-04-2024 05:08 AM
Not currently making new sets. We have to move the current stock of 3.2-3.4 stuff on the shelf.
Jpapgar 12-17-2024 05:17 AM
Moved a few sets more dyno numbers soon from pelican members?
Jpapgar 02-22-2025 08:18 AM
Back up top
Jpapgar 04-09-2025 02:33 AM
Another set shipped waiting for a few dyno results
Jpapgar 05-16-2025 05:10 AM
Monthly humpback up top
mikedsilva 06-12-2025 04:18 PM
I've been wanting to try these but until someone actually posts their results from using them, I'll sit on the fence.
Surely someone must be running an engine with these by now? Or is the "absence of feedback", the feedback in itself?
no offence intended to the seller.
Jeff Alton 06-18-2025 07:54 PM
Mike, I am sitting on my 74.4 stroke 98mm set waiting for a build where the client wants to turn a 3.2 into a 3.4. We have been doing smaller and largerdisplacement and watercooled mostly lately. But I am looking forward to buiilding a motor with them.
Cheers
Jpapgar 10-16-2025 03:41 AM
8 sets left in stock
PeteKz 10-16-2025 05:27 PM
What size pistons are in stock?
Rivet 10-21-2025 08:50 AM
Hello guys,
I just wanted to share a dyno chart of a motor that Will Pyle assembled for one of our customers last year, numbers are to the wheels.
It is a 3.4 liter 3.2 with KR75 cams, Apgar pistons, SSI and Dansk muffler, twin plug ECU controlled, PMO throttle bodies. I supplied the Maxxecu engine management system and install support to Will and calibrated it on my dyno. I found the pistons to make for a very efficient combustion chamber requiring less ignition timing to reach MBT.
Two thumbs up from me.
http://forums.pelicanparts.com/uploa...1761061693.jpg
PeteKz 10-21-2025 11:15 PM
What full-throttle, full-advance timing did you find for max torque?
