-   -   My new piston 3.0+ (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1120123-my-new-piston-3-0-a.html)
faapgar 06-03-2022 06:13 PM
My new piston 3.0+
My new piston design is about to arrive.Developed in 1997 I had Mahle make 5 sets of the prototypes.CP just made 2 sets off the prototype mold.Patent is pending.The best piston design for a 911 ever.I have a second version in process.More power than anyone else has done before.The early version was in a 2.8 built on a Turbo case.66 stroke by 95mm bore.Used special 3.6 early heads that the stud spacing was narrowed and done by the best drag racer in the North East.Heads flowed 326 cfm.Port size was not changed much but the devil in the details.The motor made 373 hp at 9300 rpm.It MADE TORQUE from 244 ft.lbs at 4400 rpm-249 ft lbs at 8900 rpm.They will come in the nest day or so.I will post pics.I just waited 22 weeks for these sets.I am lucky I am 71 and my 2500 sq.ft.shop is paid for.Tough to be in a business with our current supply chain.I have made 95-98-100mm pistons.Due the design and shape these make 20-35 ft. lbs. torque from 4000-6500 rpm.Coming soon.Ciao Fred
mepstein 06-03-2022 06:22 PM
Fred - Sounds terrific. Congrats!
Jeff Alton 06-03-2022 08:01 PM
Cool, congrats. We did a similar project for our M96/97 pistons.
Why don't you explain to us what makes this the "best piston design for 911 ever" and show us the supporting data? There is much more in that motor you describe than the best piston to create the power you claim.
Would love to see pics of those 964 heads with the narrowed stud spacing as well. That is cool.
Looking forward to hearing and seeing all the details and supporting data.
Cheers
Cheers
faapgar 06-04-2022 03:04 AM
new pistons
When they arrive I will share pics.Fred
H-viken 06-04-2022 04:45 AM
Do you have a video of the 2.8 revving? Must sound amazing when it gets above 8k!
faapgar 06-04-2022 06:13 PM
new life foe 911 piston
They should be here by Wed.I will have pics.They are not normal looking.I will offer a narritive as to why they work.Ciao Fred
porschyard 06-05-2022 04:05 AM
Looking forward to the pics Fred, after our recent chat I have a picture in my minds eye of what they look like and more importantly why they work. Richard
Neil Harvey 06-05-2022 07:15 AM
Fred,
Its great that more new products are coming for these older engines. There is no reason development should stop. The more that get involved and offer alternative options the better for all.
Good job my friend.
faapgar 06-06-2022 04:26 PM
New stuff
Pics in the next two days with an explanation why they work.Thanks Fred
faapgar 06-06-2022 05:06 PM
New stuff
Dpmulvan 06-07-2022 06:59 AM
I would be interested in a set of Fred pistons, are you selling any sets? Or have an agreement with any manufacturers or are these just personal use?
al lkosmal 06-07-2022 08:10 AM
Fred,
Looking forward to learning more......
regards,
al
faapgar 06-07-2022 09:28 AM
new shape of pistons
I am waiting for the UPS guy or gal to show up TODAY and make me smile.These will be available for sale.Long wait from CP is the downer though.These 1st two sets are 98mm.One for 66 stroke and 70.4 for the other set.
blue911rsr 06-07-2022 10:10 AM
What length rod and what pin size
faapgar 06-07-2022 12:42 PM
Pin size
The wrist pin size for these is 22mm.For motors with aftermarket rods 19mm will be offered.On 66mm stroke I use a 132mm rod with 98mm bore for a SS 3.0.Still waiting for UPS to come today.
faapgar 06-07-2022 02:12 PM
No UPS yet
I got my 1st smart phone a month ago.I got a text picture of the piston last week I just found.So I took a picture of the picture on my phone to give you something to look at.http://forums.pelicanparts.com/uploa...1654636139.JPG
faapgar 06-07-2022 04:21 PM
Pistons are here at 7:10 PM.
IT IS LIKE XMAS.Here we go.I am making Philly Cheese Steaks for 6 people out of Filet Mignon.So details tomorrow.The pics for now.http://forums.pelicanparts.com/uploa...1654643732.JPG
I http://forums.pelicanparts.com/uploa...1654643732.JPG
faapgar 06-07-2022 05:21 PM
here you go
bump
mepstein 06-07-2022 05:25 PM
Fred - I'm in. I'm building a 3.2SS. I don't care about HP, I just want it to rev. ITB's and Motec. We'll talk soon. Thanks, mark
MST0118 06-07-2022 05:49 PM
Your steak dinner sounds good and making me hungry!! Pistons look cool too!
snbush67 06-07-2022 06:54 PM
Looks great! I think that design will greatly enhance the scavageing capabilities and serve to reduce the flat spots. So awesome! Where does the line start?
Jeff Alton 06-07-2022 08:38 PM
Hey Fred, I trust you worked with Jerry at CP on those?
They look great!
Good job getting them done and pushing the envelope.
Cheers
Classic11 06-08-2022 05:22 AM
I am too scared to ask even but I need to, how much $$$?
faapgar 06-08-2022 02:31 PM
Details about this design
I first used this design in the late 90,s.Dyno test on 2 engines.It has higher sides with about 1mm clearance between the head & piston.This creates the squish area that directs the combustion burn location to center of the piston.By dropping the piston center when it fires it is centrally located.I took the 2.8 race engine apart after dyno test and 2 hours of track time.The carbon trace was in the center.The high rising sides were clean.An added advantage of the dropped center it flows more air and increases CFM flow as the air has lowered resistance to climb over the peak of the piston.It reduces heat to the cylinder head to cylinder sealing surface as well as more heat flows through the exhaust port as combustion point is in the center of the piston.Hank Clarkson Engineering was my dyno guy and Peter Dawes as well.He liked the idea and tried to do that with the engines he built.He was very talented and built a wide variety of engines.Icarp from Pelican used to hang out with him and knows all the different motors he did.The 2.8 built on 76 turbo case with hi flow 3.6 heads made 373hp at 9300rpm.Torque curve from 244 ft.lbs at 4400rpm was flat till its peak at 8900 with 249.5 ft.lbs.It is a very efficient design.Reduces detonation due to charge location so single plug is ok.
dg567 06-08-2022 03:15 PM
Fred, those look great. Can’t wait for my set to come in for the 3.2SS you’re building me. Since they sent you the 3.4 pistons by mistake, maybe we can build a 3.4L from a brand new 3.2 case I have.
icarp 06-08-2022 06:50 PM
Fred, I am so glad you pulled those out of the closet .
I believe this is one of the most secret parts of a 911 , it has been held close for many years .
Well done Fred
I will be buying a set and run them on a few different engines . on eddy brake dyno.
Here we GO !!!!!!
ICARP
porschyard 06-09-2022 05:05 AM
Very cool Fred, that is some serious top secret engine porn 😂
icarp 06-09-2022 09:03 AM
Some well written info that may help in the understanding of why these pistons work so well.
It turns out that even in a well-balanced charge of fuel and air, there are highly localized “pockets” of varying mixtures at the “local level.” By “local level” you should think of a bunch of little fuel molecules huddling together “over here” and “over there” in different places inside the cylinder as the piston is rising up towards top dead center and starting down. Some of these pockets may be so lean (or so rich) that they won’t burn at all, some may be in the combustible range, and some may be perfectly mixed, “ready to go,” so to speak.
As an aside, this explains another little mystery. In theory, the “ideal” mixture for our engines is about 15 parts air and 1 part fuel (by weight), which should result in no oxygen and no unburned fuel molecules going out the exhaust pipe. But we’ve long known that a slightly richer mixture would produce slightly more power. Why? Because the theory breaks down a little when the charge contains those little pockets of varying fuel-air mixtures. Some of the oxygen molecules do not find fuel molecules quickly enough to burn, and they remain unused or unburned at the ideal ratio. By supplying just a bit more fuel for the lonely oxygen molecules, more total fuel is burned, a bit more heat is generated, and less oxygen escapes out the exhaust pipe without having had a chance to mate.
Now, somewhere about 20 to 25 degrees before the piston reaches top dead center (TDC) of piston travel, the spark plug lights the fire. The flame front starts spreading from each spark plug, slowly at first, then more rapidly within the cylinder. This flame front plays an important role in all of this. Ever stick your hand up close to a hot flame? Not in the flame, just close? It gets hot fast. There is a LOT of infrared heat being given off by that flame front. It travels at the speed of light. Maybe a few million times (or so) faster than the flame front is traveling across the cylinder. That infrared radiation heats up those little local pockets of fuel and air.
"Striving for somewhere between 14* and 18* ATDC of maximum pressure in the combustion chamber
This depends on , bore, stroke , RPM , Comp ratio , and maybe a few others ." ICARP
Further, since the piston is rising rapidly in the cylinder, those little remote local pockets of fuel and air are also experiencing a sudden rise in pressure.
Still further, because the flame front is a combustion process, it, too, is causing a further and much larger rise in pressure in the cylinder.
Hold that thought for a moment, while we mention the time scale for all this.................
This is the article, It beautifully explains what might take place in your combustion chamber
https://www.avweb.com/features/pelicans-perch-43detonation-myths/
Ian
faapgar 06-09-2022 03:17 PM
the truth is coming out
Thanks Icarp.This topic is releasing a lot of skeletons from the closet.Those isolated pockets are part of the detonation demise as well.A great commentator on this would have been Chris I think from England who passed away about 2 years ago.But there are people out there that are very sharp who should chime in.10 minds are better than two.I try to learn everyday or this would not be fun anymore.This is a great forum because of the sharing.
blue911rsr 06-09-2022 06:38 PM
What’s the weight of your 98mm piston k
faapgar 06-10-2022 03:41 AM
piston weight
The piston weighs 430 grams.
Jeff Alton 06-10-2022 08:46 PM
Fred, looking at the recessed dome, are these designed for twin plug? Or are you getting the performance gains on single plug?
Cheers
faapgar 06-11-2022 03:28 AM
The performance gains work with single plug very well.The 2.8 race engine was twin plugged.The recessed dome contains the charge in that area.
Jeff Alton 06-12-2022 08:16 PM
Cool, great product.
Cheers
Henry Schmidt 06-16-2022 06:53 AM
Hi Fred
I like your "new" design. Very impressive.
One thing we questioned with CP and JE pistons is the sharp transision between valve pockets. We discovered that by simply rounding those "sharp" edges that horse power gains were substantial and compression loss is minimal. A measured 5 HP in 200. Theoretically, it promotes better exhaust gas expulsion. I'm sure you considered this mild modification but I thought I would mention it for people who didn't.
Cheers
http://forums.pelicanparts.com/uploa...1655387413.jpg
faapgar 06-16-2022 09:17 AM
smoother edges
Thanks Henry.As usual you have great suggestions with learned thought behind it.Thank you for chiming in.All thoughts and inputs are greatly appreciated.
dannobee 06-17-2022 03:13 PM
We learned in nascar cup racing years ago that a piston with a parabolic dish will make the most power. (Assuming that it fits with your needed compression.) It might be beneficial to refine the "top" a bit more from a flat machined top to a slight dish.
Mahle has a very informative white paper on Pistons and Engine Testing that might help in other areas.
https://fdocuments.in/document/pistons-and-engine-testing.html?page=1
faapgar 06-17-2022 05:41 PM
Change of the flat top to a dish shape
Hey Dannobee.Great input. The original two 2.8 SS Engines I built on 76 Turbo case had the dish in the center like a 3.6 piston.Good COMMENT.I have 3 shapes for these as far as design.The 2.8 made 373 hp at 9300 rpm.I copied the dish from the 3.6 piston with higher sides as I wanted to get the squish to force the charge to the center as I figured that all those guys at Porsche were smarter than I would ever be.Thanks for your insight.Fred
faapgar 06-17-2022 05:58 PM
corrction from a previous post
I spoke with Icarp alias Ian Carpenter a few days ago and I was incorrect to describe him as hanging around at Hank Clarksons shop.He was an employee and the more he learned the more Mr.Clarkson paid him.Well he learned very well as I value his opinion to this day.It is nice to have people like him to contribute to this forum.Ciao
faapgar 06-19-2022 05:53 PM
new pistons
The last set should be sold tomorrow with a deposit.Thanks Pelican.Fred
