Banned
Engine
Can anyone decipher this early engine? This is a replacement rebuilt engine we bought back in 2003. I’m finally getting it going, should be a 2.0L, number looks ground? Can’t see type number? No stars, what is going on?
I believe this is a mag case due to which face its on, but looking for direction. I vaguely think this was a 914-6 engine per my bad memory. Running this in my 66 until I rebuild the original 907388 engine. ![]()
Try not, Do or Do not
It's impossible to decipher the engine make based on those numbers. They certainly are not factory stamped. They might be the ugliest re-stamp I've ever seen.
The 914/6 had it engine number stamped on the top of the case adjacent to the oil thermostat. If there is a number up there it might be an original six. From what you have presented, it still a mystery. 914/6 engine number location.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-02-2025 at 07:40 PM.. |
Banned
thank you! Found it.
