Engine Stand Yoke
Good Morning,
Long time forum lurker here.. im starting a Carrera 3.2 tear down and rebuild project next month, i've been looking for a used 5 arm engine yoke (with the notches to clear a crossover pipe and engine oil cooler). Is anyone looking to part with one? |
Buy one, use it, and sell in the classifieds here for 80% of what you paid for it. Pass it along.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
+1Jeff, then build a good strong engine stand to go with it.
1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover |
Do you have plans/drawings for the above engine stand? I have a couple of HF engine stands and am looking to modify one for a coming 3.2 pull myself.
Agree with the buy and then pass along. |
I do have plans, will pull out and post jmd88
Stand plans
This is what I have. This stand is a copy of the engine stands Jerry Wood uses to hold up the heavy 930 plus. I asked if I could copy it when I was taking his engine building class about 2002. Mark
It's a 914 ...
You can also buy the rolling stand from Harbor Freight for like $75. The Porsche engine yokes are compatible with it.
Agreed. That JW stand is sweet but, not necessary. Unless you’re a pro or, doing multiple rebuilds. You’ll spend well over $100 on materials. Not to mention the time investment.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
We have 8 similar stands store bought. Look essentially the same. I will take pics of them tomorrow.
Drive it like u stole it.
I use an OTC 2012A stand. Its very similar to the Jerry Wood design and it works with the yoke.
https://www.goapesonline.com/P/3022/23020OTCAlbEngineSt
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
https://www.harborfreight.com/automotive/lifts-cranes-stands/engine-stands/2000-lb-capacity-foldable-engine-stand-69522.html
1982 911SC |
thanks for the input all, i just went with the P01 knock off. After a few seconds of grinding, the yoke cleared my crossover pipe flange no problem. Now to get the heat exchangers off..
