Correct cylinders for 1994 964
Hi All,
Are these considered to be the correct cylinders for a 1994 964?
Thanks! Q.
Old 09-12-2015, 02:22 PM
Try not, Do or Do not
Henry Schmidt's Avatar
964 103 915 22 is the correct number for the piston and cylinder set for a 1994 Porsche 964.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-12-2015, 03:21 PM
The box shows the correct number for later model 964's, however the cylinders and pistons seem to be the earlier cylinders/pistons....
Old 09-14-2015, 08:26 PM
The pistons and cylinders shown in the pictures are definitely the late style 964.
Early 964 cylinders had the conventional style sealing surface No gasket and no head support around the studs.. Much like the 3.2 Carrera cylinder.
There were two different late cylinder types that used gaskets. One used the asbestos/paper gasket and the other used an aluminum ring style gasket.
The cylinder pictured appears to use the asbestos style gasket.
Henry Schmidt
Ph: 760-728-3062
Old 09-15-2015, 01:20 AM
Does either have an advantage over the other, Henry?
Thx. Quinn
Old 09-15-2015, 08:42 AM
Thx. Quinn
The aluminum ring is the later style so at least one engineer at Porsche or Mahle thought it was a better idea.
I don't have enough information to give a definitive answer.
Henry Schmidt
Ph: 760-728-3062
Old 09-15-2015, 09:21 AM
ok, I'm even more confused than usual. PET lists 964.103.915.22 for use in M64.01, 02, which is C2 NA, as well as M64.50 - which is 964 Turbo. ?!?!?!
PET lists 964.103.915.25 for use in M64.01/02, after 1991, only - not turbo. Did 964 turbo and NA use the same pistons?
Reparations for neanderthals!
'70 914-6, 1965 Mustang GT - RIP, '74 911, '01 Box S
'12 Ducati 848 Evo - RIP, '16 Yamaha R1, '13 Aprilia RSV-R
Old 08-15-2022, 01:02 PM
The 91-92 964 Turbo was actually 965. It was a full fin 3.3 liter engine. 97mm bore.
These are definately not those pistons/cylinders.
I don't know what later Ps&Cs look like but something in my memory tells me they had a elivated deck piston.
Henry Schmidt
Ph: 760-728-3062
Old 08-19-2022, 06:33 AM
superninety's Avatar
I show the part number that I used for the updated P&Cs for my 964 to have been
964-103-915-22
These are the upgraded P&Cs and appear to be the same as your photos
Been in the car for several years now.
Robert Callaway
PCA | Early S Registry | R Gruppe
1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S
1962 S90 Coupe - Gone, but never forgotten...
1985 Targa - A distant memory...
Old 08-20-2022, 02:33 PM
Tags
1994 , 964 cylinders , 964 pistons
