5.7 GT1's Avatar
78 SC Cam help
I’m currently rebuilding the top end on my 78 sc. I’m excited to finally have another Porsche project again since my last build
Taking the EFI Plunge
In the process I decided to upgrade to L&N 3.2 SS cylinders and JE 9.5:1 CR pistons.
Here are the other changes being made to the engine (most being induction and exhaust) in the process:
-964 cams
-ssi’s
-dansk 2 into 1
-xfaktory Itb’s
-coil on plug ignition
-xfaktory ecu
My question is: can some tell me if my valve clearance is ok running the above?
I have already purchased all of these parts and won’t be making any changes if I’m fine on valve clearance. I’m also curious on recommended cam timing?
Thank you!
Old 08-05-2022, 10:22 PM
You likely will get more traffic in the technical forum. Reaching out directly to KNIGHTRACE, icarp, and jpnovak will get you what you need. Not an exhaustive list, but it’s where I first would turn. Sorry I’m not more help.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 08-06-2022, 07:28 AM
5.7 GT1's Avatar
Thanks jac
Old 08-06-2022, 10:05 AM
You'll have to check P2V clearance to be sure, but JE's usually have pretty deep valve reliefs. There should be tutorials here on how to check if you're not familiar with the procedure.
Set 964 cams at 1.25mm.
Old 08-06-2022, 11:14 AM
5.7 GT1's Avatar
Thanks for your advice dannobee. I was hoping someone has the same build specs and can chime in to help me understand if I don't need to worry about checking the valve to piston clearance. I guess I'm being lazy. Once I get started on assembly next week I most likely will be checking v to p clearance before setting the cam timing.
Old 08-06-2022, 04:02 PM
Visual Test Inspection......
GTI,
Assemble your motor and do a visual test inspection using a dial indicator. You also need P7E/P7I valve compressors. If you don’t have these compressors, simply remove the valve springs from the cylinder head prior to partial engine assembly. Then measure the actual valve clearance with the crankshaft @ Z1 TDC and no cam tower installed.
Tony
Old 08-07-2022, 06:52 AM
I would rather be driving
jpnovak's Avatar
964 cams will easily clear JE pistons.
but, If you are going with those pistons you should seriously think about changing cams to something else. A DC40-108 would be my choice. more midrange torque, more top end. Just better matched to ITB/EFI setup.
Old 08-07-2022, 08:21 AM
I am my 911's PO
'78 SC's Avatar
I ran 9.5 CR JE pistons (95mm) with the stock cam re-ground to 964 profile and had no clearance issues, just as Jamie says.
I still suggest you check the clearances, especially if you have done anything that could change deck height. I used the technique described in Waynes's rebuild book. Be sure to check throughout a full cycle (720 degrees of crankshaft rotation) since the point of closest approach between the piston and valves is not at TDC.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 08-07-2022, 09:07 AM
5.7 GT1's Avatar
Originally Posted by boyt911sc View Post
GTI,
Tony
Thank you Tony! This is really helpful.
Old 08-07-2022, 09:23 AM
5.7 GT1's Avatar
Thanks Jamie, I would jump on a set of DC40-108 cams if they were available. Unfortunately, it seems to take months to get anything these days and I will have everything ready to assemble next week.
Old 08-07-2022, 09:29 AM
5.7 GT1's Avatar
78 SC, That is good advice. I used Wayne's book to build my last motor (and will use it for this one as well), but it was a low compression 930 motor. I know that with a 9.5:1 CR I need to be careful with valve to piston clearance.
Old 08-07-2022, 09:35 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
There is a lot of good buzz around William Knight's M1 cams, and he may have them in stock. He's very generous with advice after making you clearly identify your goals.
knightrace911@hotmail.com
615.969.4917
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 08-07-2022, 01:28 PM
5.7 GT1's Avatar
615.969.4917
Thank you!
I’ll reach out to him.
Old 08-07-2022, 03:57 PM
