930/02 vs 930/04 Case Differences?
Bottom line question is what would it take to put a 2.7 crank and IMS in a 930/04 case?
Yes I researched that here! Sorry if old material.
Old 08-31-2022, 12:22 PM
Main bearings... crankcase bore is different.
Old 08-31-2022, 01:11 PM
Flywheel end of the crank…
Bruce
Old 08-31-2022, 01:32 PM
Walt Fricke's Avatar
Right - the SC era cranks have a larger flywheel end, taking a wider ID/OD bearing in a case cast wider for the bearing. Porsche did this so it could use a 9 bolt flywheel attachment and needed the larger diameter to fit the extra holes.
To fit the earlier crank you'd have to machine some kind of insert to restore the ID for the 2.7 bearings, and figure out how to keep it in place. Sounds doable, but gee whiz, why? Doesn't sound cost effective unless you are a machinist and like the challenge.
This assumes you don't have the rather rare early 930 case for the ~1976 Euro Carrera 3.0 or the very first 930 Turbo 3.0. Those are desirable for guys making short stroke 2.8s or other cylinder diameters with the 66mm crank.
Old 08-31-2022, 04:04 PM
