Permatex Anaerobic doesn’t seem to be curing. Is this a problem??
I installed the heads and cam plate 48 hrs ago. I used Permatex Anaerobic gasket maker. It does not seem to be curing. At least the squeeze out is still not cured. Should I be concerned?
1984 Hellbronze Metallic M491
Old 09-13-2022, 05:53 PM
rsscotty's Avatar
Sealant
As it says below, the lack of oxygen is what cures this sealer.
Old 09-13-2022, 06:12 PM
Yeah I read that, but I think I just needed reassurance! I have never used it before and this being a pretty monumental project for me I have just been overly concerned.
I did do a small test piece tonight on some other aluminum pieces I have. I hope to get up in the morning to that fully cured! I would then feel better! :-p
Thanks for the reassurance!
Old 09-13-2022, 07:15 PM
Anything that squeezes out will never set.
Old 09-13-2022, 07:29 PM
It's a 914 ...
stownsen914's Avatar
I remember worrying about this with loctite 574 years ago. The stuff you see won't set since it's exposed to O2. If you want to convince yourself, put some between a couple pieces of metal you dont care about and let it set, and then check it.
Old 09-14-2022, 06:07 AM
Use the tried and true methods of sealing your engine or you’ll end up with an oil leak.
Old 09-14-2022, 08:29 AM
The Complete Engine Sealant Thread...
Old 09-14-2022, 08:32 AM
I did that last night and it was cured this morning! I just needed the confirmation! Thanks for the response!
Old 09-14-2022, 09:14 AM
I apply the 574 real thin. The key to it is, don’t let surfaces contact, maintain air gap until all the hardware is in place, then close gap and rattle all nuts down and torque.
Old 09-15-2022, 08:13 PM
Well I was definitely more generous with the Anaerobic Permatex than that!
Old 09-16-2022, 09:27 AM
Racer
winders's Avatar
That is too much....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 09-16-2022, 11:19 AM
917_Langheck's Avatar
Just a bit...
____________________________
If it's not leaking, it's out of oel...
Old 09-16-2022, 11:45 AM
I can’t remember exactly what it said in Dempsey’s book (Maybe it was a video I watched?) , but I believe it said use a generous amount and that you want to see some squeeze out. I guess we will see if it leaks! :-/
Old 09-16-2022, 12:02 PM
wow.....should squeeze out everywhere. LOL I just apply a bead around the perimeter per the factory manual ( for Loctite 574) same stuff basically.
H
'77 1973 911RS Backdate, 2.7 liter w/webers
'70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress
'75 911 RSR street car in progress
'77 930 Replica '75 993 GT2 EVO race car , 3.6 TT
'79 928 5 speed money pit in progress
Old 09-16-2022, 12:19 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
The problem with applying too much is where does the squeeze out go? Answer, into engine cavities and oil pumps and cam spray bars etc. With sealers, more is not better.
1986 Targa Guards Red
2021 MT09 SP
Old 09-17-2022, 07:45 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If your cam towers/heads have not been installed, I suggest you start over. If that area leaks you're looking at 25 hours to go back in and reseal. There is no way to repair without disassembly.
Remember, if it leaks after installation you have to remove the engine, remove the intake and fan shroud, disassemble at least one side [remove chain box cover, break down the cam chain sprocket, remove the rockers, remove the cam, pull the heads, separate the heads from the cam towers, clean off old/perhaps dry sealant] and then reassemble. Just setting the cam timing makes a redo time prohibitive.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-20-2022, 12:54 PM
Hmmm..
So I am confident now its all cured. Why do you think it will leak? I cleaned and removed all the squeeze out. I also used some aluminum scrap and tested the sealant and it cured no problem. Thanks!
Old 09-20-2022, 05:15 PM
It's a 914 ...
I’d be less concerned with a leak than I would that there’s a thicker layer of the sealant than you really want between the heads and cam towers.
Old 09-20-2022, 05:51 PM
Do you think torquing everything to spec would just squeeze any excess resulting in the proper clearances?
Old 09-20-2022, 05:55 PM
Hmmm..
If the excess creates a tolerance issue, you'll know when the cams are installed.
If the cams turn easily by hand the thick layer of goo might not matter.
Roll the dice and hope you make your number.
On this table, the unexpected is the house.
Henry Schmidt
Ph: 760-728-3062
Old 09-20-2022, 06:02 PM
