Originally Posted by Peter M View Post
I've PM'ed the details to you Todd.
Cheers
Thanks mate - appreciate it
Old 09-25-2022, 09:52 PM
Racespec has them as well, but still in the US. I know Racespec ships worldwide all the time https://racespeconline.com/collections/sensors/products/motec-hs230-hall-speed-sensor
Like others have said, the hall effect can from anyone. I'm sure there is a good source close to you.
Old 09-27-2022, 04:30 AM
call them I called yesterday and they answered
Old 09-27-2022, 12:52 PM
Rasant?
D.
Old 09-27-2022, 02:08 PM
yes
Old 09-28-2022, 06:40 AM
Originally Posted by OSC911 View Post
Hey Mike, thanks for the heads up. I'll absolutely check this and let you know how I get on. I'm away with work at the moment but will check as soon as I get home. That makes a lot of sense now that you mention it.
The sensor adapter has a threaded 3/8" hole that the crank sensor threads into - is this the hole you elongated or the adapter mounting hole part where the nut goes onto the stud and holds the adapter in place? Appreciate your help as this is giving me a lot grief.
it was the adapter mounting hole where the nut clamps down on the stud that the distributor is normally secured... elongating the hole in the cam/crank sensor unit, allowed it to be rotated so that the sensor tip was centered over the trigger wheel.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 09-30-2022, 12:28 PM
Thanks Mike - i'll let you know how i get on.
Todd
Old 09-30-2022, 01:32 PM
Hey, I like your YouTube videos.....very informative.
You can never show us beginners too much...
D.
Old 09-30-2022, 01:43 PM
911 Mania
Rasant’s website is still up, so I phoned the contact number and Noah answered. He said Andrew is trying to sell the business.
"When the debate is lost, slander becomes the tool of the losers." Socrates
Old 10-13-2022, 09:12 AM
The website has only been back for a few days. It was shut down up until then. All a bit strange.
Old 10-13-2022, 01:43 PM
