Interesting Video of boring out cylinders
I didn't know this was possible.. just happened across this video of a shop in the UK that bore out the 95mm cylinders to insert a steel liner...
Always learning.
www.aircooledporsches.com.au
Old 11-19-2022, 02:48 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Thanks for posting Mike. P content starts at 10:52 although the first part is also interesting.
1986 Targa Guards Red
2021 MT09 SP
Old 11-20-2022, 05:02 AM
It's a 914 ...
stownsen914's Avatar
I've heard of doing this. I hear some builders prefer the iron or steel liners for high boost turbo applications.
Old 11-20-2022, 05:17 AM
Have never understood why though. Why add material that increases ring friction over the original liner material, when the "original" type if liner material is available for repair work.
Old 11-21-2022, 05:48 AM
Registered Minimalist
75 911s's Avatar
Don't they do this on the Alusil cylinders too?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-21-2022, 07:46 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Unique bores [95mm in a 2.0 case, or 101.5 in a 3.0 case] and increased cylinder pressures make these modified cylinders an interesting option. We've made quite a few cylinders over the years and our standard procedure is to Nikasil the cast iron liner, something we learned from the NASCAR builders.
Is this a state-of- the-art option? maybe not but after all, we're working with less than revolutionary design parameters.
These are JB Racing's version of a cast iron [Biral] cylinder we're using on a 2.0 vintage race engine going in a 914-6 GT were building in house.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-21-2022, 07:48 AM
