You need Fuel rails. (can be made if there is none available, a set of 3.2 might be modified) Adapters for injectors (I made some for my 924) A tps adapter (this can be tricky) Crank signal, fit 36-1 or 60-2 trigger wheel. (Patricmotorsport have a flywheel with 60-2 trigger) As ECU I have used 3 different systems, the latest is a Maxxecu, a local to me Swedish company and that is really easy to use, very capable and pretty affordable. Available worldwide of cause.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
MAXXECU is a very good ECU. Tons of capability/programability...
We have done plenty of ECUMASTER BLACK ECU as well. Very good/capable system for not a ton of money. We run them in a couple of race cars, our E85 full modified Mini Cooper. Very good. MegaXXXX Why bother with a toy system in this day and age... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 11-12-2022 at 09:51 PM.. |
Thanks again for all the input. I'm sticking with CIS for now. I plan to spend the winter getting more familiar with the system so I have a better chance of keeping it running in the coming years.
-Vic |
I am my 911's PO
The basic system on a 1978 (no oxygen sensor or Lambda control) is easier to diagnose than 1980-83 cars, but you will need appropriate tools: a smoke machine to locate air leaks, a gauge set to measure system and control pressures, a simple vacuum hand pump to check the WUR and vacuum limiter and, most importantly, a good understanding of how the system functions. One excellent source of information is the late, great Jim Sims' jimsbasementworkshop. There are also several Pelicans who understand the system quite well and post regularly. Good luck and enjoy your classic.
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive Last edited by '78 SC; 11-19-2022 at 07:40 AM.. Reason: type |
