Replacing cylinders and pistons with engine on a table.
Hi guys, I'm about to put another set of pistons and cylinders into my engine which is on a hydraulic table right now, and since I don't have the needed engine stand yoke or the adapter needed to hang the engine on the engine stand (and can't find it anywhere where I live), do you think its possible to do that job with the engine setting on the table ? or do I really need to spend that much money into the tool and shipping (very expensive) to do it with the engine on a stand?
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
I’ve done more than few total builds in the distant past on a table. It’s just so much easier with the correct tools and a stand. Good luck!
It's a 914 ...
Anything can be done of course, but it sure makes it easier mating the case halves to be able to rotate so you're doing the operation vertically instead of horizontally, and rotate as needed to do cylinders, heads, etc.
Just doing P/C set replacement should be easy enough on the table. I would never attemtp to assemble a bottom end on a table....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
get yourself the correct yoke there are not expensive, VW will work for this job too
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 12-18-2022 at 11:35 PM.. |
Bought mine on Amazon for 287.00 with free shipping!
I know guys its a cheap tool for you, but for me it will be at least twice as expensive by the time it reaches here, the shipping prices become very expensive!
Standard everyday engine stand works just fine if you have one, or can beg or borrow one.
Table
I made a wooden cradle. Then did it on the kitchen table. Split the cases. I didn't find any issues at all.
Lyndon |
[COLOR="Lime"]Easy to say when you have mini wheats to keep you going!
