3.2 gasket questions
88 carrera Engine is out and gonna do valve guides and clutch. After much
reading seems wrightwood gasket set is the preferred set to use. Does anyone know if the rsr seals are included? Does this set come with the white valve stems seals? And how about any engine oil seals that may be included? Tks for any help. also any advice on relieving pressure on carrera tensioners? |
Talk to Wrightwood and tell them what you want. No problem.
Just pop the tensioners out and on reassembly, slowly squeeze them in a vise until you can stick a drill bit or the like into the hole at the top side. You will feel the pin go in farther as the piston is almost all the way in.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 01-30-2023 at 08:54 PM.. |
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
