Banned
911 engine rebuilt
Hi All, I need some advice. I am in the process of getting a 1984 Porsche 911 Targa’s engine rebuilt. I have had it aqua blasted and wondered what is the best thing to seal the casing to keep it looking good?
Old 03-09-2023, 11:25 AM
Wrong Image......
Look very closely at your motor. You posted the mirror image of your motor. This motor does not exist in the real world. Were you trying to trick the viewers?
Tony
Old 03-09-2023, 01:09 PM
GG Allin's Avatar
Right hand drive car?
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 03-09-2023, 04:27 PM
Banned
Tony
Old 03-09-2023, 05:39 PM
good call tony, very observant
Ian
That Tony is sharp
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 03-09-2023, 06:03 PM
It's a 914 ...
stownsen914's Avatar
Partial credit. Was in a 911 from China or Australia.
Old 03-09-2023, 08:55 PM
I'm curious to know how they cleaned out all the blast media.. do they remove every single plug in the case?
Always learning.
www.aircooledporsches.com.au
Old 03-09-2023, 09:54 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
A product called ACF50 works well .. soaks in for corrosion resistance .. leaves a surface layer to help keep muck off.
Old 03-10-2023, 01:31 PM
AND oil squirters…plenty of engines out there that have failed from debris leftover from vapor blasting
it's not leaking....it's just marking it's territory
Old 03-11-2023, 05:59 AM
This is why I've refrained from having engine cases media blasted.
I have a case at the moment that is getting all new squirters but I am still not prepared to have it blasted.
As for having the OP case protected... could it be "clear cerakoted"?
Mask off all the mating surfaces etc and use the air-dry version of clear cerakote?
Always learning.
Old 03-11-2023, 03:02 PM
