Banned
911 engine rebuilt
Hi All, I need some advice. I am in the process of getting a 1984 Porsche 911 Targa’s engine rebuilt. I have had it aqua blasted and wondered what is the best thing to seal the casing to keep it looking good?
Wrong Image......
Look very closely at your motor. You posted the mirror image of your motor. This motor does not exist in the real world. Were you trying to trick the viewers?
Tony |
Right hand drive car?
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone |
Banned
good call tony, very observant
Ian That Tony is sharp
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
It's a 914 ...
I'm curious to know how they cleaned out all the blast media.. do they remove every single plug in the case?
Always learning. www.aircooledporsches.com.au |
Rosco_NZ
A product called ACF50 works well .. soaks in for corrosion resistance .. leaves a surface layer to help keep muck off.
AND oil squirters…plenty of engines out there that have failed from debris leftover from vapor blasting
it's not leaking....it's just marking it's territory |
I have a case at the moment that is getting all new squirters but I am still not prepared to have it blasted. As for having the OP case protected... could it be "clear cerakoted"? Mask off all the mating surfaces etc and use the air-dry version of clear cerakote?
