JoeMag's Avatar
Nose length dim's 964/993 & GT3 crank, same?
Is this dim the same on a 993/964 and a GT3 (non-4L) crank?
Old 03-06-2023, 10:09 AM
JoeMag's Avatar
...actually what I'd like to know is if someone has a Gt3 crank, could you let me know what this dim is?
Old 03-07-2023, 08:57 AM
356RS's Avatar
You will most likely get an answer before me but I will get measurements off my GT-3 crank and post it today.
Mark Jung
Bend, OR
MFI Werks.com
Old 03-08-2023, 07:56 AM
356RS's Avatar
I get close to 67mm. My GT-3 crank is not tapered at the end like yours.
Mark Jung
Bend, OR
MFI Werks.com
Old 03-08-2023, 10:21 AM
JoeMag's Avatar
thanks...
Old 03-09-2023, 09:58 AM
targa72e's Avatar
I have both a GT3 and 993 crank to check.
These are the only numbers I could find on GT3 crank.
My snout is not tapered either.
GT3 Length. 2.63"
993 crank snout
993 measurements 2.65"
I also measured a 3.2/3.3 crank for comparison. 2.29"
I believe Rothsport makes crank pulleys with the correct offset for later cranks in earlier cases.
john
Old 03-10-2023, 01:40 PM
JoeMag's Avatar
Thanks for breaking out the collection John...
The 964 crank in the pic measures 2.65". Look'n at your pic, the GT3 measurement might have been on the radius a little as I believe the 964/993/GT3 have same nose length after some other side conversations. Neil noted to me that the later longer noses are 0.35" longer which corresponds to your 3.2 measurement too.
Old 03-10-2023, 02:32 PM
