Can anyone identify these factory race camshafts?
Factory 4-bearing center-lube camshafts
Casting numbers
911-105-155-00
911-105-156-00
I still don't know what is the diameter of the bearing journals but does anyone recognize those numbers above? What spec/model are they for?
Thanks in advance.
Old 05-09-2023, 01:28 PM
Following
All 4 bearing center oil race cams were small journal. Don’t know if the casting numbers are part numbers. By part number, not RSR or 935 by my info. What size are the cam nuts and the thread pitch. Could be home made?
Old 05-09-2023, 05:59 PM
These look factory to me. I don't know the cam nut size or thread pitch as of yet.
Old 05-09-2023, 06:22 PM
Fine thread 42 mm nut size, on the couple I built.
Bruce
Old 05-10-2023, 04:40 AM
So, nobody knows what model the cams are for?
906?
ST?
2.8 RSR?
3.0 RSR?
SCRS?
Carb or MFI?
Sprint or Endurance?
One of the clues is the first three digits of the casting number:
"901" tends to be early (usually pre-69) whereas "911" is probably after that. But don't take my word for it.
Old 05-10-2023, 07:22 AM
3.0 RSR in 74 was first 4 bearing race cams. I ruled out all 3 bearing cams, 906, R, ST, 2.8. Those look like fine thread, recessed end factory cams. That’s all I got.
Old 05-10-2023, 07:55 AM
All you have are the casting numbers. Any other info is normally stamped on the end of the cams, but even then, it's no guarantee of anything because they could have been reground.
If you really want to know what you have, get out a dial indicator, a couple of rocker arms, and a degree wheel and measure them. The short cut would be to use a cam carrier and a rocker arm and measure valve lift, then compare to a chart of the race cams. But even then, you still wouldn't know the duration without using a degree wheel.
Or, if you happen to know an automotive machinist with a "cam doctor," he can put them in some V-blocks and tell you what you have.
Old 05-10-2023, 08:47 AM
safe's Avatar
+1
The cast number are just a number for the blanks before grinding.
Magnus
Old 05-12-2023, 06:51 AM
Travis Neff's Avatar
Part number for a blank, uncut cam? I found this.
https://www.early911sregistry.org/forums/showthread.php?80721-FS-Porsche-Camshafts
72 914-6 GT Conversion 2.7
82 911 SC Coupe
78 SC Targa Hotrod
Old 05-12-2023, 09:31 AM
Originally Posted by Travis Neff View Post
Thanks for the link. I did not see that before.
Thanks everyone.
Old 05-12-2023, 12:06 PM
If they are real "FACTORY RACE CAMS " the numbers will be missleading on purpose ,
All info is set to mix up the user , factory privilage eyes only. It's in code
VS JUST CUSTOMER RACE CAMS
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 05-12-2023, 07:47 PM
Measure the journal diameter to narrow it down, that is about as easy as wanting info gets.
Then if you still strike out, send them to Web and ask them to evaluate them on the Cam Dr (see exact open and closing times for both sides, total lift etc) and learn what they are exactly, in case they have been modified. This will tell you what lobe centers they are on also, in case folks desired a changed.
Upland, CA
Old 05-17-2023, 06:30 PM
