Where to recondition 3.2 crankshaft
I bought a used 3.2 crankshaft to eventually replace the one in my '84 with a damaged snout. I want to go ahead and get it reconditioned so it's ready when the time comes, but I'm in no hurry.
Where are the recommended go-to places for this? Is CCR still working out of TX? Marine Crankshafts in CA? Others? Last edited by tchiers; 07-14-2020 at 05:07 PM.. |
I liked Armando and CCR. Seeing you’re not in a hurry, quality is choice.
Might repair your 84 nose.... Bruce |
Can anybody confirm up to date contact info for CCR?
I’ll give it to you on PM
Bruce |
Marine Crankshaft in LA.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Armando might have a reputation for quality, but he is not a good businessman. We sent him over a dozen cranks to do and we ended up having to have a local customer go collect them from him after he had them for over half a year and many failed promises. He doesn't answer his phone and his voice mail is always full. Just understand this if you do have him do work.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
I just had a great experience with David at Marine Crankshaft Repair. Highly recommend him and his work. Jim
I've used Marine Crankshaft with good results.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
crank
+1 for Marine crank in O.C. in calif.
I used Mile High Crankshaft Repair in Denver after spinning a rod bearing.
Scott Wilburn 1988 911 Carrera 3.4 L 1998 M3 1984 308 QV |
I’ve used CCR and Marine and they’re both good. Of the 2, I have slight preference for CCR though.
Like I said earlier, and others have said. Marine Crankshaft is the place to go. NO drama, Reasonable turn arounds, high quality work. An actual proper business.... Far from a one man band.
Not saying Armando does not do great work, but as a business we can't screw around, and have a situation like Charles at LN had..... Search the forums, not just his one, and see if you want to send your crank there... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 06-04-2023 at 06:18 PM.. |
