Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Wrightwood racing gasket st
I'm doing a top end on a '83 911sc. I've read here that Wrightwood Racing is the preferred gasket kit. I've found the kits for the 3.2's, but not the 3.0. Can someone point me to a supplier?
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD 1976 914 2.0 Lime Green Metallic - Completely stock |
gearhead
Try Steve at Rennsport Systems. Or Henry at Supertec. I think they both can supply you with Wrightwood kits.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Now in Florida !
Thanks Matt
Henry at Supertec is where I got mine for a 3.0
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
Just got a set of Wrightwood racing valve cover gaskets. Should I use any sort of sealant on these? Did a search but could not find anything.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Try not, Do or Do not
Surface the covers for your best chance at success. Standard fiber Coated fiber (green with a spay on coating) Fiber gaskets with a silicone bead. And of course, cork for the 2.0 purist.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I have the green ones with the coating. I'll clean the surfaces thoroughly but was just wondering if sealant may help...belt and suspenders...
Does Wrightwood make complete engine gasket sets for 2.2L engines? I searched but couldn't find one for a 2.2L.
This allows you to customize things like exhaust, port size and base shims.
PCA Member since 1988
Henry, what valve cover gaskets do you prefer now for 3.0/3.2 engines?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Gasket with a silicone bead.
Thanks. That's what I'm using.
