964
This is probably the wrong site but I’ve been trying to find some information out about putting a 964 3.8 in a 914. I’d like to know if anybody has run the number 16 AN and the number 12 An oil line up through the passenger side heater, duct and into the front trunk area to the dry, sump tank and cooler , Will the 12 and 16 fit through the heater tube at the same time . thanks for any info . slamming out
It's a 914 ...
Try 914world, it’s been done many times
Try not, Do or Do not
You might try running the engine to oil tank hose on one side and supply hose on the other. Ben McFarland makes some pretty cool GT oil lines that may help you resolve you dilemma.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-11-2023 at 06:33 AM.. |
Very hard !
