9.6/1 vs 9.9/1 Compression Ration
Guys
Deciding for my 2.5 weber carbs , DC30 cam, 70.4 crank
Have new under fender cooler
Whats your thoughts ?
Frank
Gold71
Old 06-01-2023, 08:04 AM
You won’t probably notice a difference in power
1977 911S - high mileage and a bit rough but mostly original. Soon to become a bit of a hot rod.
Old 06-01-2023, 01:49 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by 82 sportsc View Post
Guys
Frank
Lean towards the lower compression ratio for three reasons.
First, with Mod Solex cams, dynamic compress will be higher than with most larger spec cams so detonation will be a issue.
Second, you will not notice a performance difference between 10:1 and 9.5:1
Third, as soon as the green people realize that the best way to get old cars off the road is to restrict octane, be on the look out for liberal states restricting octane to 85?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-02-2023, 04:06 AM
PCA Member since 1988
Thanks for that "Third" reason. I hadn't considered that as a method of getting old cars off the road.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-02-2023, 01:49 PM
Jeff Alton's Avatar
Measure the CR, do not rely on the "advertised" CR, it is rarely correct.....
www.turn3autosport.com
Old 06-10-2023, 06:51 PM
As "advertised" might as well say as "fantasized".
We're building a 906 engine and the "10.4:1" Mahle pistons aren't even 9.2:1.
The big valve 906 chambers are close to 74cc and CP tapped out trying to find 9.6:1. We even went to Wyseco for their 13:1+ super pistons and they weren't even 10:1.
It all reminds me of dyno numbers after the "correction" is applied.
Henry Schmidt
Ph: 760-728-3062
Old 06-11-2023, 09:29 AM
Jeff Alton's Avatar
^^^^^^^ this...
Old 06-12-2023, 04:55 PM
