9.6/1 vs 9.9/1 Compression Ration
Guys
Deciding for my 2.5 weber carbs , DC30 cam, 70.4 crank Have new under fender cooler Whats your thoughts ? Thanks Frank
Gold71 |
Ace of Spades
You won’t probably notice a difference in power
1977 911S - high mileage and a bit rough but mostly original. Soon to become a bit of a hot rod. |
Try not, Do or Do not
First, with Mod Solex cams, dynamic compress will be higher than with most larger spec cams so detonation will be a issue. Second, you will not notice a performance difference between 10:1 and 9.5:1 Third, as soon as the green people realize that the best way to get old cars off the road is to restrict octane, be on the look out for liberal states restricting octane to 85?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-02-2023 at 04:10 AM.. |
PCA Member since 1988
Thanks for that "Third" reason. I hadn't considered that as a method of getting old cars off the road.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Measure the CR, do not rely on the "advertised" CR, it is rarely correct.....
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
We're building a 906 engine and the "10.4:1" Mahle pistons aren't even 9.2:1. The big valve 906 chambers are close to 74cc and CP tapped out trying to find 9.6:1. We even went to Wyseco for their 13:1+ super pistons and they weren't even 10:1. It all reminds me of dyno numbers after the "correction" is applied.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-12-2023 at 06:50 PM.. |
^^^^^^^ this...
