993 heads
guys - I have a few 993 heads and noticed (1) has cracked and missing chunks of ceramic liner in the exhaust port. Can this be fixed? How to fix it? It looks like 35% of the liner is missing? Is there a high temp epoxy to fill in and build up to repair? Open to thoughts, suggestions and possible solutions from the group. Thanks! Jim Dorociak
jdorociak@gmail.com
Old 01-17-2023, 05:22 PM
safe's Avatar
They crack... I've only seen 3-4 3.6 engines apart but all had cracks and missing parts of the liner. My engine is missing some of its liner.
Probably not ideal, 35% seems like a lot, but I wouldn't worry unless you have a turbo. The common method of repair I think is to replace the head with a better one.
Magnus
Old 01-19-2023, 12:10 AM
jdorociak@gmail.com
One of Neil Harveys posts somewhere (recently) stated he has some sort of coating that he brushes on in layers.... No idea what he uses of course but it would be worth reaching out to him.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 01-25-2023, 01:53 AM
Thanks Mike - I sent him a PM and will do a search as well. Jim
Old 01-25-2023, 10:58 AM
Racer
winders's Avatar
This is why I went with Xtreme heads for my race engine. Yes, Xtreme heads are expensive, but, for my situation, I will save money in the long run not having to deal with damaged ceramic inserts or cracked heads.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 01-25-2023, 12:16 PM
Thanks Scott. Not making a race engine, but a solid street engine. Is there any repair that can be done to "fix" the missing pieces of ceramic? I have to assume everyone who had missing ceramic did not throw those heads away. Jim
Old 01-25-2023, 02:09 PM
It's a 914 ...
stownsen914's Avatar
I've heard several shops mention here and elsewhere that they have repair procedures for damaged ceramic inserts. At least one mentioned an epoxy substance.
Old 01-25-2023, 02:33 PM
PCA Member since 1988
I can't see how any epoxy based material would hold up to the heat in the exhaust port--that's why they are made of ceramic in the first place. Whatever they brushed into the exhaust port must be a ceramic based thermal barrier coating (TBC), that must be heat cured in an oven first, then finish cured by running the engine. See one of your local TBC specialists. FYI, I had TBC applied to the exhaust ports of my engine I built a year ago. So far, so good (6000 miles).
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-28-2023, 11:12 AM
Mike Billings's Avatar
If the ports want to be bigger, then why fight them? (sarcasm, haha, not really a question)
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 01-30-2023, 03:28 PM
"Be the port."
Old 01-30-2023, 11:00 PM
Peter, do you have any reliable data indicating a reduction in head temperature?
Old 07-15-2023, 07:19 PM
Nope. TBC's will reduce head temps. How much, and whether it makes a difference in the longevity of the heads is an open question.
Old 07-16-2023, 03:36 PM
I use cerakote thermal barrier on 356 exhaust/heads/valves piston top, super durable. Prep is key:
- ultrasonic clean
-heat up head to 300 to bring up any oil left over
-ultrasonic clean again
- blasting with aluminum oxyde
- ultrasonic clean
- dry
- spray cerakote
- cook for 1hr at 300
Old 07-16-2023, 05:21 PM
