Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Wrightwood racing gasket st
I'm doing a top end on a '83 911sc. I've read here that Wrightwood Racing is the preferred gasket kit. I've found the kits for the 3.2's, but not the 3.0. Can someone point me to a supplier?
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 01-14-2016, 09:54 AM
gearhead
Try Steve at Rennsport Systems. Or Henry at Supertec. I think they both can supply you with Wrightwood kits.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-14-2016, 11:17 AM
Now in Florida !
Thanks Matt
Old 01-14-2016, 12:12 PM
Henry at Supertec is where I got mine for a 3.0
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 01-14-2016, 02:55 PM
Just got a set of Wrightwood racing valve cover gaskets. Should I use any sort of sealant on these? Did a search but could not find anything.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 06-21-2023, 04:48 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Depending on your engine, Wrightwood makes four different materials used in valve cover gaskets. That said, no sealant is necessary.
Surface the covers for your best chance at success.
Standard fiber
Coated fiber (green with a spay on coating)
Fiber gaskets with a silicone bead.
And of course, cork for the 2.0 purist.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-21-2023, 05:14 PM
I have the green ones with the coating. I'll clean the surfaces thoroughly but was just wondering if sealant may help...belt and suspenders...
Buck
'88 Coupe, '87 Cab,
Old 07-05-2023, 02:04 PM
Does Wrightwood make complete engine gasket sets for 2.2L engines? I searched but couldn't find one for a 2.2L.
Old 07-06-2023, 03:21 AM
All Wrightwood Racing gasket sets we sell or custom made. We tell them what you're building and they customize the kit to match your build. That means if you're building a carbureted 2.7 you won't get CIS components.
This allows you to customize things like exhaust, port size and base shims.
Henry Schmidt
Ph: 760-728-3062
Old 07-06-2023, 05:46 AM
PCA Member since 1988
Henry, what valve cover gaskets do you prefer now for 3.0/3.2 engines?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-06-2023, 10:32 AM
Gasket with a silicone bead.
Henry Schmidt
Ph: 760-728-3062
Old 07-06-2023, 12:59 PM
Thanks. That's what I'm using.
Old 07-06-2023, 09:45 PM
