Weber IDTP 40 jetting/setting for 2.4T
Hey Collective,
I have a 914-6 conversion. 2.4 liter. T cams. ‘67 aluminum case, 2.7 counter weighted crank and rods. (Rods balance by Ray Litz). MAHLE P&C 46mm intake and 40mm exhaust valves. Rebuilt motor has around 25K miles on it. 123Ignition distributor with OEM CDI. Carbs are 40IDTP3C. They were rebuilt for a 2.7 engine. Owner states they ran brilliantly. On my 2.4 configuration, I get a lot of popping upon initial acceleration dip in. They are nicely synchronized and it idles on cold start perfectly around 1100rpm. Wondering if the jetting/set up is too much for my 2.4. Any insight. Is there a list of what the carbs should be running for a 2.4T Thanks in advance. Also posted in 911 forum. Wasn’t sure what was best one to get eyes on. Cheers, Dion |
My 2.4T with a PMO Weber conversion came with the following jetting
Weber 40 IDA 3C Main jet: 130 Idle jet: 55 Air correction jet: 180 Emulsion tube: F1 Venturis: 30 mm If your carbs were set up for a 2.7 you will probably have to reduce main jet size. Optimizing jet sizes is a lengthy process but worth the effort. Just went through the whole process and am very happy with the outcome.
Regards, Guenter 73.5 911T, mod Last edited by buster73; 08-01-2023 at 10:36 AM.. Reason: correction |
buster73 . Thank you very much for this information. I will make a note of your settings. Time to take these apart then.
Thank you Cheers,Dion |
Under the radar
![]() You will be shooting in the dark, unless you can measure your air fuel ratio. And you are leaving a lot on the table with T cams IMO. Buster has a good starting point.
I have a set of 30mm venturis if you need them $80.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
