totle's Avatar
7R case with 100mm spigot
Hi
Have had a 7R case for some time laying around.
It has been opened to 100mm
I guess this at a time for a 3.0 build.
What and Where can I get hold of cylinders for this ?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 08-04-2023, 12:50 PM
It's a 914 ...
stownsen914's Avatar
100mm is an unusual size, isn't it? I believe 2.7L is 97 mm, and 3.0L is 103 mm (had to google those). One thing worth considering is whether there is enough meat left on the cylinder stud threads to accommodate case savers?
Old 08-05-2023, 05:57 AM
Sealing the bottom of the Cylinder may also be an issue. Its hard to see from the photo.
Old 08-05-2023, 10:34 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We can make any odd ball cylinder /spigot combination and may actually have the cylinders you need in stock. We've made a few 95 mm cylinder kits for 2.7.
That said, the better option is to return the case to a more stable configuration.
IE: install an insert in the case to reduce the spigot diameter.
We just did one on a vintage racing 2.0. This modification can also facilitate a long rod configuration.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-05-2023, 12:50 PM
totle's Avatar
Hi Henry
I also thought the possibility to have inserts made.
Is the inserts something you can sell?
Living in Norway, so expensive to have the case shipped.
Trond R.
1986 944 Turbo
Old 08-06-2023, 09:12 AM
Originally Posted by totle View Post
Hi Henry
Short answer is no. The inserts are custom made for each application.
Any machinist capable of properly fitting this kind of insert should be capable of making the inserts.
Henry Schmidt
Ph: 760-728-3062
Old 08-06-2023, 09:54 AM
47silver's Avatar
Henry
The inserts are very clever. Great idea
Old 08-08-2023, 05:49 PM
Constitutional Liberal
Turbo_pro's Avatar
Originally Posted by 47silver View Post
Henry
Over the last 30+ years, the Porsche community has had the opportunity to watch the guys at Supertec come up with some pretty cool ideas to keep these old cars on the road.
Head studs, rockers, idler arms, 906 goodies and my favorite MFI enrichment. That little invention makes owning an MFI car far more enjoyable.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 08-09-2023, 07:04 AM
