Thanks Lowo
Is it Christmas?
Yesterday I got my cams and rocker arms, and Head Studs. Is it Christmas?
Report on Cylinder Heads
I called on my Cylinder Heads and they are getting new guides and they should be ready tomorrow if the seats aren’t screwed up. Valves and springs are all good. He said these heads have never been touched. Man these 3.0’s are something else.
Getting Case Ready to Ship
I pulled all the case studs out to clean, zinc plate, and yellow chromate. Then I cleaned the thrust bearing and #8 and lightly greased them. Then greased the crankshaft and installed it the case to ship to Competition Engineering in Lake Havasu. Clutch cover and flywheel are going as well. I measured the HxWxL and found a Coleman Cooler to ship in. Sixty bucks on Amazon.
Case Cleaning, Case inspection, squirter cleaning, micro polishing crank, and balance the flywheel and cover together. About $700
Interesting, I have to look for that one. I have seen videos of valves rotating in the head which was eye opening. The speed and direction changing and both valve spinning totally independent of one another.
If you find a link please share. Quote:
The Heads Return
I just received my heads that Steve Becker serviced. (Becker6.com) He does excellent work. I was amazed how fast he refurbished them and the look great. They only needed to have the guides replaced and the valves and seats touched up.
Wow! These Flat Sixes are made to run forever. ![]()
Exhaust Stud Headache
One thing I found out with regard to exhaust port suds, is don’t even think about pulling them. On the fourth stud, in snapped 1” above the head surface. then heated it with ocy/acetylene torch and snapped it flush. It’s a good thing i speak “Easy-Out” as a second language. I drilled it out dead center and tried to relax the remaining stud and it still wouldn’t come out. More heat, bigger drill and still wouldn’t come out. Finally I ended up drilling the hole to the normal size to start tapping a blank hole. it worked well and only got steel crips when i tapped it, no aluminum.
I pulled all the exhaust studs out my heads. Probably half snapped. I just welded nuts on them. The heat from welding yields the studs. They come out pretty easy after that...
Maybe i’ll try again. I just had the heads reconditioned and didn’t want to make the assembly lube run and burn. May disassemble one at a time. I have the tools and I rebuilt a set on my 911T some 35 years ago.
Detroit, what replacement studs are you using? I was hoping ARP made a set, but having difficulty find them during my limited internet access at the moment. Last edited by porschedude996; 09-18-2023 at 10:32 PM.. |
My plan was to use something in stainless, but Henry's Ti studs look pretty intriguing.
I'm using a set of Ben's headers though. The flange thickness differs from a factory manifold. I need to get that stack height defined before ordering anything. |
DIY wrencher
88 911 Carrera 3.2 G50 - driver 77 911S - rust bucket backdate project IG: @lukas.matzinger |
I have changed my view on leaving them and not replacing the studs. I’m not sure if i’ll go to ti.
If you've ever looked at where exhaust studs really take the heat and rarely break, look no further that how Caterpillar puts studs on their over the road turbocharged diesel trucks. Looong studs, then the exhaust flange, then a spacer of about 1" thickness, then the nut. The added length of the stud allows the expansion to occur over the length of a much greater area than concentrating it right at the cylinder head/flange.
I tried the Liquid Wrench soaked for two days and no success. I just purchased a magnetic induction heater for bolt and stud removal. I’ll see how that works.
Oil Spray Bar/tubes Orientation
I was installing the cam/rocker oiler tubes in my cam towers and found a clue to the orientation. The larger center two cross drilled holes in the tubes align with the recessed dimples in the tower. Of course the small spray holes go down into the cavities towards the cam.
Exhaust Studs Redirection
After thinking I reconsidered replacing the exhaust studs. I choose to replace the studs and tried the usual penetrating oil and professional type double nut to extract said studs. I still didn't want to flame on with the valves and valve seals installed. I found a fastener heater and it will arrive tomorrow. I'll see how that goes. I ordered a set of studs from Silverlake Inconel studs. If you going to go, go big.
Banned
Would really love to see this when you’re done, I’m pretty sure it would be nice
Looks like a solid build.
Do you have any specific power/rpm goals or are you simply documenting a solid build for posterity? I'm from Palmdale California. What part are you in? Last edited by Madness; 10-03-2023 at 04:25 AM.. Reason: Sub'd |
DIY wrencher
However the studs should then be cool when you try to extract them (hot they will be too soft). I like to heat up the entire head with a hot air gun (which I strap to a tripod as it takes a few minutes) and then cool off only the studs with freezing effect spray and a small nozzle. You might still have one or two studs break but removing them in a mill now is much better than having them break in a few years when the engine is assembled and in the car, and you want to remove the exhaust. Your inconel or ti studs will last a lifetime without worries.
