-   -   Which head studs for a 964 rebuild? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1145943-head-studs-964-rebuild.html)
Axel84 09-08-2023 04:18 AM
993? supertec?
what say you
Classic 911 09-08-2023 05:52 AM
993 turbo studs
Flat6pac 09-08-2023 05:55 AM
Supertec, love the fine threads and no need to measure depth or pay the Porsche tax
Bruce
Henry Schmidt 09-08-2023 07:29 AM
Supertec is a good choice for those interested in improved design features.
Quality corrosion resistant aged 17-4PH steel
Precision ground, heat treated, rolled threads
Fine thread for more precise torque and force retention
Highest quality (12.9), 12 point serrated flange nut
Ground and hardened washers
Additional threads at case end for more engagement [important for non-inserted mag cases]
Longer over all length for custom rod length applications
Ease of engine assembly
No need for height adjustment
Piston can be installed without the stud interference.
Price includes studs, nuts and washers.
http://forums.pelicanparts.com/uploa...1694182567.JPG
Jeff Alton 09-09-2023 07:33 PM
What sort of build are you doing? What is the Intended use of the motor? Figure this out first.
If you are choosing to replace the OE ones, Supertech will be around the same cost as stock or 993 and be an upgrade..... Especially if you factor in new nuts....
Cheers
Turbo_pro 09-10-2023 10:26 AM
A quick heads up to those looking to up-grade their head studs.
Their are those who swear by the Dilivar studs [mostly because it's what Porsche sells] but you should be aware that there are imitation all-thread studs on the market. If you really buy into the claims made by Dilivar proponents, keep in mind that the imitation studs may not perform as expected.
That said, I have Supertec studs in 3 of my Porsche builds.
winders 09-10-2023 01:17 PM
Originally Posted by Turbo_pro (Post 12086334)
Their are those who swear by the Dilivar studs [mostly because it's what Porsche sells]...
This is not true. The people that swear by the Porsche 993 Twin Turbo head studs use them because they actually work the best for them and their builds. Just about all of the top high output race engine builders use the 993 Twin Turbo head studs. They don't use them because it is what Porsche sells. If that were the case they would be suing Porsche rods and pistons....
Turbo_pro 09-10-2023 02:30 PM
Can you list any of the top output engine builders who have tried Supertec studs and rejected them? My understanding in talking to the parts guys at Supertec is that demand out strips supply.
tick...toc...tick...toc.
People building expensive engines in every category are reluctant to try new things. 993 head studs are good enough for some maybe even most. Innovation doesn't guaranty acceptance.
winders 09-10-2023 05:03 PM
I am not arguing against anything here. I am calling you out for a comment that is incorrect. I have no idea which top high output engine builders have tried Supertec studs.
All I know is when I asked around I found out these engine builders used the 993 Turbo head studs. When I asked why the answer was they are the only ones that have worked for them. In others words they swear by them because they work not because Porsche sells them.
Feel free to use and recommend any product you want. I don't care what people use in their engines. All I know is my engines get Porsche 993 Twin Turbo head studs because William Knight recommended them and the guys out there that build the best high performance larger bore engines use them.
Turbo_pro 09-10-2023 06:30 PM
"Calling you out". What a child, is everything a competition with you?
I've had the same kinds of conversations with top flight engine builders for 40 years and the answer is generally the same. They change based on proven innovation or manufacturers incentives. Basically, if it ain't broken don't fix it. That's why there are stupid race car engine mods still in use long past the sell by date.
winders 09-10-2023 09:21 PM
Dude, I was "calling you out" (i.e. challenging what you said) in the sense that I was responding to the comment you made saying that builders use 993 Turbo head studs because it is what Porsche sells. Challenging a falsehood is not "childish".
Turbo_pro 09-11-2023 04:00 AM
The childish part is the naiveté exhibited by your hero adoration. You ascribe quality based on a nebulous feeling you have about who uses a product with zero understanding of why they use that product.
Maybe you can get William Knight or any of these other great builders to come on this thread and actually explain the thought process he used to select Dilivar head studs.
Turbo_pro 09-11-2023 04:17 AM
Dude
The real purpose of my post was to warn prospective buyers that there are bogus "Dilivar" studs being sold and they might not perform as advertised.
You picked a random comment, an opinion to negate the entire purpose of the post.
Your head stud feud is well documented but does it bring anything of value to this or any other thread?
Zuffenwerker 09-11-2023 06:12 AM
Dilivar studs are non ferrous so it’s pretty easy to tell a fake
stanglife 09-11-2023 08:03 AM
Since this is seems like a general opinion thread - anyone use or have any objections to the ARP ones? I already have this set on the shelf - any reason to use something else?
https://arpstore.com/products/cylinder-head-stud-kit-for-porsche-2-0l-3-8l-air-cooled-engines-911-930-turbo-premium-austenit
Jeff Alton 09-11-2023 06:23 PM
Have used them many times will great success. Have them in a current 993RS build (actual RS).
That said, we are going to start using Henry's studs and give them a try.
Cheers
safe 09-12-2023 12:11 AM
For a stock rebuild 964 (most 964 cars won't be driven in anger anymore) cheap steel studs would probably be fine, its what Porsche used. Anything better than that adds insurance. Depends on the use of the engine.
porschedude996 09-12-2023 06:33 AM
So i’m gathering that I could use new dilivars on a stock 3.0L and be good for years/corrosion. My 1983 studs lasted thus far and i’m changing because of age. Some corrosion was observed when the engine was recently torn down.
Henry Schmidt 09-12-2023 06:53 AM
Porsche made the mistake of using two different materials in heads studs on both the 911SC and 3.2 Carrera. Steel on the top and Dilivar on the bottom.
If you are replacing your studs, I recommend using 24 studs of whichever variety you choose. If you don't want to avail yourself of a more advanced stud, I recommend the Canyon stud. Standard configuration with a higher quality material. Great corrosion resistance, precision ground, heat treated and rolled threads. I consulted on the material selection.
I believe they are available from our host. Part#: 10-0115-101-M105
Henry Schmidt 09-12-2023 08:39 AM
The 964 was never fitting with " plain steel" studs from the factory. In the late seventies Porsche committed to the Dilivar stud to deal with warranty issues [seeping on cool down]. They struggled with design after design and finally settled on the all-thread monstrosity. It was never designed for as a performance enhancement.
safe 09-12-2023 09:11 AM
Mine was and my buddy's RS. Maybe a row vs us thing.
winders 09-12-2023 09:24 AM
Yet the 993 Turbo "all-thread monstrosity" head studs are the predominant choice for use in high output high performance large displacement Porsche air-cooled engines.
Heck, even Singer uses them in their builds.
Turbo_pro 09-12-2023 09:57 AM
Cool more hero worship.....
I'm pretty sure every race car used biased ply tires until radials hit the scene.
Some still do......
dannobee 09-12-2023 11:46 AM
At the stealership level, we rarely if ever used aftermarket head studs and we cringed when replacing the broken studs because we'd all seen brand new, just out of the package Dilavar studs break right after torquing them up. Either a few minutes later, or the morning after. It left us with zero confidence in the product while having to wear a happy smile with the customer. The problem is "intergranular corrosion" if you care to look it up. It's a manufacturing/heat treating problem. And like Henry, we saw enough of the earlier ones go bad that we no longer cared what promises the latest iteration had, we just didn't trust them. From what I understand, the 993 turbo ones have fixed all of the problems. They might be the greatest thing since sliced bread. But once bitten, twice shy. Especially now that some aftermarket studs have seen zero failures.
Sort of off topic, but most of the "radials" that I've used in nascar weren't true radials, but more of a hybrid, being a belted tire with a smaller bias angle than the bias ply tires. If you ever see one dismounted, take a look inside and you'll see the bias angle.
It's tough to make a true radial tire that can withstand 200 mph continuous. Not to say that it hasn't or can't happen, but look at all of the tire problems in the current Cup cars.
Neil Harvey 09-14-2023 08:18 AM
That's a pretty bold statement. I don't use them but then again, I'm must not in the high performance business, I guess???? Even I don't know what others use. Just what we do and why.
There are advantages to head studs that have nothing to do with clamping the parts together. Anything that can be incorporated into a part to make its use better and easier to use. Why not??
To clear up a few issues, Singer do not build their own engines. Pinks did some. Pinks were never really in the Porsche business, so using anything aftermarket would be chosen on risk, I assume. Now Porsche builds the Singer engines here in the US and Porsche will always use their own parts.
An absolute sales pitch, what about our studs? We even supply Titanium Exhaust studs that will never fail due to the heat stress that the steel studs suffer from. We also offer the through bolts with the center dowel locking the case half's together.
http://forums.pelicanparts.com/uploa...1694703878.jpg
http://forums.pelicanparts.com/uploa...1694703878.JPG
Jeff Alton 09-14-2023 12:21 PM
^^^^^ Nice looking parts Neil. I assume the through bolt O-ring slides over the locating dowel section easily?
Cheers
PeteKz 09-14-2023 01:50 PM
Neil, thanks for making the titanium exhaust studs. I’ll differ in attributing exhaust stud failures to heat stress. It’s been my observation of not only several handfuls of Porsche studs, but also hundreds of studs in other engines that the exhaust studs fail primarily due to corrosion. However, your titanium studs would certainly help in that regard. Stainless steel studs also would be much more resistant.
Henry Schmidt 09-14-2023 03:03 PM
We haven't really seen a heat issue with exhaust studs either with the caveat that turbos get crazy hot.
The only exhaust studs we found required something special were the turbo charger mounting studs. For that we made a 10 X 50mm hard anodized titanium stud. We found better longevity with the anodize process.
We enhance the body diameter to create a more precise hole fitment to reduce movement from excessive vibration.
http://forums.pelicanparts.com/uploa...1694728244.JPG
winders 09-14-2023 04:42 PM
Neil,
I guess you don't know what the word "predominate" means in the context I used it. It doesn't mean "all". It means "being most frequent or common".
I don't know what head studs you use. I've never heard your name mentioned when it comes to choices for building high output large displacement air-cooled race engines. I know who built the engines in all the fast air-cooled cars I have come across in my 12 years of racing and you have not architected/built any of them. So I don't know what level of performance you build to. Your engines might be the best or just okay. I have never come across one. I have come across competitive engines from Peter Dawe, Jeff Gamroth, Jae Lee, Kevin Roush, Sol Synderman, William Knight, and Mat Lowrance.
Singer would not choose an engine builder that used inferior parts in their engines. Period!
Scott
Neil Harvey 09-14-2023 06:53 PM
Originally Posted by winders (Post 12089769)
Neil,
Scott
Yes you are correct. I'm not well known in the Porsche world as I stay in the background supporting many of the shops you listed.
My background is not building Porsche engines like many of the shops you listed. My background was spending many years building engines for F1, Cosworth and BMW, then coming over here and building some Indy engines before working for Toyota building the IMSA 4 Cyl Turbo engine, V6 Offroad and the Toyota Atlantic engine. Then spending a few years working for Andial in the race engine dept., doing all the dyno testing on the 962C engines and some other Porsche race engines. After leaving Andial, I started PD continuing building 962C race engines, some air cooled turbo engines and when the water engines came in around 2000 developing many parts for those. A few years ago when we were asked to build high end high performance air cooled engines we set about designing and developing parts for the air cooled engines, many shown in my air cooled developments post on this site.
So, yes we are not well known in the air cooled "club" scene as we have been too busy designing and building slightly more developed engines.
I wonder, does that make me capable of building a less developed Porsche air cooled club engine? Don't know myself. That I will leave up to customers to come to me and ask.
BTW, I'm buried with work building engines with parts we developed and shown in my air cooled developed parts on this site.
I'm tired, I need to lie down and take nap.
Neil Harvey 09-14-2023 07:15 PM
Is this enough qualification to join the "club" race engine builders fraternity?http://forums.pelicanparts.com/uploa...1694743788.JPG
Same engine, different day.
But you are right, not many of these in the Porsche club scene. I can only wish I had the chance to built an air cooled large displacement engine instead of having been tasked to rebuild this engine.
Who wouldn't.
BTW, never have I seen any of the shops you list build any of these either. So that makes us all even.
Axel84 09-14-2023 10:55 PM
lol mic drop from neil
KNIGHTRACE 09-15-2023 12:47 AM
This forum is here to HELP people make good choices on there builds or find support.. I ran across this thread and hesitantly posted. I am willing to help anyone that reaches out to me and advise them for their application. I use 993tt on high Preformance builds and I am currently about to try some supertech studs.On the exhaust studs I use steel ones with "copper locking nuts" Never have problems removing them even 15 to 20 years later. Turbo-pro You mentioned my name above asking me to explain my "thought" process on delivar. I think more than most do.
porschedude996 09-15-2023 03:16 AM
Henry, please explain how you are getting the studs out without snapping them off. I tried mapp Gas, and i’m afraid to put too much heat into the with a Oxy/acetylene torch . Head’s are fully assembled.
Helix8 09-15-2023 04:39 AM
Neil,
Those who know you know. Thank you for your contributions to Motorsport.
Henry Schmidt 09-15-2023 05:26 AM
If I understand you correctly, you are asking how to remove exhaust studs without breaking them. The answer is heat and patience but even with that, you may have some broken studs. That is why we always remove exhaust and intake studs prior to the rebuild process. During our process, we remove the studs that come out easily, then with the broken or stubborn ones we machine them out and clean the threads when appropriate and insert the threads that don't survive. This process is done in a simple knee mill so while the head is in the fixture we have the opportunity to resurface the exhaust flange.
http://forums.pelicanparts.com/uploa...1694780604.JPG
The studs in the picture are for the turbo housing. Those studs rarely come out so we go straight to the machine process. As Neil has stated, plain steel is not your friend when it comes to hardware in extreme heat applications.
Neil Harvey 09-15-2023 05:59 AM
Originally Posted by Helix8 (Post 12089969)
Neil,
Thank you. That's very kind.
I apologize if I came across as a dick. Sometimes, you need to make a point without actually replying to the question. Pictures often mean a lot more.
Anyway, its Friday and I have lots of work to do, "building high performance, large displacement air cooled engines".
They don't build themselves.
Henry Schmidt 09-15-2023 08:51 AM
Some of the custom hardware we've made over the years to make even our non-racing projects better.
If only I had a real engine architect to help us plan our projects.
http://forums.pelicanparts.com/uploa...1694792887.JPG
mepstein 09-15-2023 09:19 AM
I love the fact that there are really great engine builders that contribute to this site but to assume someone doesn’t know their craft because they aren’t a big online contributor would be a mistake. Some of the top guys are just busy building engines. I’m lucky enough that we speak to Peter Dawe almost every other day but I doubt he has a pelican log in. And believe it or not, he has differing opinions on head studs to his peers. There’s multiple ways to skin the cat and learning why a particular part gets used is often as important as the actual endpoint.
Turbo_pro 09-15-2023 10:30 AM
You are absolutely correct about assumptions based on website contributions.
That said, these are all just opinions and the expertise offered to assist DYI builders is priceless.
Questioning expertise based on some nebulous "racing" credentials is nothing more than an authority fallacy.
Assuming that an application suited for racing as selected by an expert must be the best for all applications because the expert is the best is simply not credible.
