WYDBODY1986's Avatar
Curil T on cylinder base gaskets timing
I have a timing question for you all. If I install the pistons and cylinders with curil T on the base gaskets and tighten them down with hold downs and leave them till the next day I have a chance to install the heads and the cam housings will I have a problem with the Curil T?
Do I need to wait till I have a full day that I can get everything assembled and torqued from cylinders to cam housings?
Old 09-14-2023, 11:26 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The purpose of using Curil T on base gaskets is the fact that it never hardens.
Cylinders on 911 air-cooled engine a constantly in flux (IE: moving from heat expansion and contraction) so a high temp, flexible sealant is best.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-14-2023, 04:44 PM
Thank you Henry, I thought that was the case but I wanted to check to make sure. I’m finding that breaking the assembly of the engine down into stages has been helpful to keep me from feeling overwhelmed.
Brian
Old 09-14-2023, 05:17 PM
Martinlassmann's Avatar
Hi Brian,
had the same issue 2 month ago.
The cams wouldn't fit well and after 1 night I could retourq Cyl 2 and 5. Then the cams fits perfect and now the engine runs and have no leaks
Martin
Old 09-15-2023, 10:55 AM
Thanks Martin that is what I was hoping for
Old 09-15-2023, 11:26 AM
